01 v70 continuous charging power?
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
Hello yall! When I had my 09 impala, I kept dashcams in my char as well as a phone charger. These devices continued to get power even after engine shut off. With this V70, i am unable to keep any of my devices powered with the engine off. I need the cameras to be rolling in case of an accident or some event. Do yall know of a method to deliver continous power?
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Has thanked: 1610 times
Been thanked: 4067 times
You will probably have to pull wire from terminal 15 on the fuse box to a connector under the dash.
CIK7
Post by CIK7 »
abscate wrote: 12 Mar 2019, 04:42 You will probably have to pull wire from terminal 15 on the fuse box to a connector under the dash.
Can you please specify, possibly take a picture? How would I make it work exactly?
IslandV70
Year and Model: 2005 V70 2.4
Has thanked: 2 times
Been thanked: 3 times
Post by IslandV70 »
The rear 12 volt outlet in my car is always on. FYI ;)
CIK7
Post by CIK7 »
IslandV70 wrote: 12 Mar 2019, 08:20 The rear 12 volt outlet in my car is always on. FYI ;)
The one in the trunk or the backseat? It seems all the trims higher than the base level have the trunk one. I dont have that. I only have 1 up front and 1 in backseat
IslandV70
Post by IslandV70 »
The one all the way back, not the one for the backseat passengers. The battery itself is back there too if you want to run a wire. Make sure it has a FUSE!
CIK7
Post by CIK7 »
IslandV70 wrote: 12 Mar 2019, 09:02 The one all the way back, not the one for the backseat passengers. The battery itself is back there too if you want to run a wire. Make sure it has a FUSE!
Ok mine is the base trim model, 2.4, so i dont have the far back 12v
CIK7
Post by CIK7 »
Is there a way to rewire both the front and backseat 12v so it will stay on always?
IslandV70
Post by IslandV70 »
Sure. Figure out where the wires run for the front outlets and rewire them straight to the battery. I have never seen a DIY on that, but maybe someone has one.
CIK7
Post by CIK7 »
IslandV70 wrote: 12 Mar 2019, 10:06 Sure. Figure out where the wires run for the front outlets and rewire them straight to the battery. I have never seen a DIY on that, but maybe someone has one.
Thank you. I am going to try to take it all apart and track the wiring.
