cam solenoid and P0171 Bank 1 Lean
IslandV70
Year and Model: 2005 V70 2.4
Has thanked: 2 times
Been thanked: 3 times
Post by IslandV70 »
My car has been getting Cam Solenoid errors since I got it and also gets P0171. I took the solenoid off and cleaned it with Seafoam and an air gun with no changes :(
So I assume the thing is beat and will order another one today. They are easy enough to replace. Does the cam error cause the lean running error or do I have yet another thing to track down?
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Most likely you have another problem to track down.
P0171 = ECM-250A Long-term fuel trim.
Diagnostic trouble code (DTC) information ECM-250A
Condition
The engine control module (ECM) receives information from the heated oxygen sensor (HO2S) about the fuel/air mixture at different loads. The diagnostic trouble code (DTC) is stored if the engine control module (ECM) registers that the fuel/air mixture deviates too much from target lambda value, leaving the long-term trim in one of its limit positions.
Substitute value
None.
Possible source
Upper limit:
  • Damaged/Dirty mass air flow (MAF) sensor
    Low fuel pressure
    Air leakage.
Lower limit:
    High fuel pressure
    Leaking injectors
    Leaking evaporative emission system (EVAP)
    Contaminated engine oil
    Oil level too high.
Fault symptoms
  • Malfunction indicator lamp (MIL) lit
    Poor performance
    May result in high fuel consumption.
Active
Past
IslandV70
Post by IslandV70 »
Looks like I might start with a MAF clean.
RickHaleParker
IslandV70 wrote: 12 Mar 2019, 09:46 Looks like I might start with a MAF clean.
Might as well. The MAF should be cleaned periodicity and it does not take much time.
Active
Past
chris11211
Year and Model: 2006 s60 2.5T
Has thanked: 7 times
Been thanked: 29 times
Post by chris11211 »
You night just have to dig in and clean the throttle body as well; as it gives off the lean fuel trim codes too.
IslandV70
Post by IslandV70 »
Funky star bits on the way.
RickHaleParker
IslandV70 wrote: 13 Mar 2019, 18:02 Funky star bits on the way.
Security Torx Bits.
A lot A lot of times you can turn the Security Torx bolt with the right sized flat-head screwdriver. You wedge the flat-head screwdriver along the post and the ends of the blade into two of the points of the star then twist.
Active
Past
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 57 times
Been thanked: 39 times
Post by EngineeringBloke »
Or grip the edge of the screw with a pair of pliers and twist! I used this myself.
IslandV70
Post by IslandV70 »
I already paid $10 for the security bits, so I'll just use them, but thanks for the ideas.
IslandV70
Post by IslandV70 »
Turns out my MAF is held in by screws, so no funky bits needed. Cleaning it was easy but it also did not change a thing :(
