2012 XC60 Fuel Rail Pressure Sensor replacement
QuietMayhem
Year and Model: 2012 XC60
Post by QuietMayhem »
Hi all-
It has been determined that my fuel pressure sensor is bad and needs replacement. I was looking for tips and help as I have never done it before. If anyone can point me in the right direction, it would be much appreciated (such as already existing step by step or video). I have ordered the part, but my understanding is it may help to bleed it prior to etc., and I would like to gather as much information as possible prior to starting. I’m brand new here apologies if I’m not following a certain protocol. Thanks ahead of time for the assistance.
gmh
Year and Model: 2016 XC60 T5
Has thanked: 28 times
Been thanked: 22 times
Post by gmh »
From VIDA, I hope this helps:
fuel rail.jpg (135.28 KiB) Viewed 8267 times
Remove pressure sensor, fuel rail (FRP)
Refer to: Pressure sensor, fuel rail (FRP)
pressure sensor.jpg (73.69 KiB) Viewed 8267 times
next diagram refers to passenger footwell:
pressure release.jpg (46.66 KiB) Viewed 8267 times
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 120 times
Been thanked: 189 times
Post by pgill »
The procedure from Gary is good.
If I were doing the Job I would buy a replacement screw.
Part number 986201
The screw is a Torx drive and there isn't a lot of space to get to it.
If you need to you can remove the entire fuel rail to get access.
One last thought: to depressurize the system you can remove the fuse that powers the fuel pump, is in the fuse box at the passengers feet. Start the car with the fuse removed let it idle and stall, then the rail pressure should be low. (That is what the pictures are showing as far as I can tell)
Good Luck
Paul
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
QuietMayhem wrote: 14 Mar 2019, 08:35 Hi all-
QuietMayhem, did you fix it? I'll mark this Solved if you did.
Also -> Amazon link
pbierre
Year and Model: T6 XC70s: '13 & '15
Been thanked: 12 times
Post by pbierre »
Paul's method for first depressurizing the fuel rail is only as good as having the correct fuse box defs for your specific model & year.
(2015 and 2015.5 owners - these are two different MYs).
Your verification of having pulled the correct fuse out is that the engine stalls out shortly after starting it up. This step is essential --
this is when the fuel pressure is being deflated.
I had the misfortune of using the a "2008 - " Electrical Diagrams" generic document -- mine is a 2015.5 XC70. I pulled the wrong fuse.
And I ignored that it didn't stall out the engine as expected. When I pulled off the fuel pressure sensor, it popped like a champaign cork, and my face & clothes got sprayed with a mist of fuel. Fortunately, I had on safety goggles. And, I had waited an hour after driving for the engine to cool off. Don't skip over the "stall out" verification like I did.
Question for "safety-oriented" Volvo engineers -- why did you get rid of the Schraeder valve for depressurizing the fuel rail on these I-6s?
