IPD sale Volvo Parts
Did you know? 🤔
2012 XC60 Fuel Rail Pressure Sensor replacement
Help, Advice, Owners' Discussion and DIY Tutorials for the groundbreaking new Volvo S60 2011+, V60 and XC60.
QuietMayhem
Year and Model: 2012 XC60
Has thanked: 0
Been thanked: 0
United States of America
QuietMayhem
Post by QuietMayhem » Thu Mar 14, 2019 8:35 am
Hi all-
It has been determined that my fuel pressure sensor is bad and needs replacement. I was looking for tips and help as I have never done it before. If anyone can point me in the right direction, it would be much appreciated (such as already existing step by step or video). I have ordered the part, but my understanding is it may help to bleed it prior to etc., and I would like to gather as much information as possible prior to starting. I’m brand new here apologies if I’m not following a certain protocol. Thanks ahead of time for the assistance.
gmh
Year and Model: 97 850 R Wagon
Has thanked: 6 times
Been thanked: 8 times
gmh
Re: 2012 XC60 Fuel Rail Pressure Sensor replacement
Post by gmh » Fri Mar 15, 2019 11:59 am
From VIDA, I hope this helps:
fuel rail.jpg (135.28 KiB) Viewed 391 times
Remove pressure sensor, fuel rail (FRP)
Refer to: Pressure sensor, fuel rail (FRP)
pressure sensor.jpg (73.69 KiB) Viewed 391 times
next diagram refers to passenger footwell:
pressure release.jpg (46.66 KiB) Viewed 391 times
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-present)
2014 XC60 T6 (2017-present)
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 11 times
Been thanked: 18 times
pgill
Post by pgill » Fri Mar 15, 2019 3:08 pm
The procedure from Gary is good.
If I were doing the Job I would buy a replacement screw.
Part number 986201
The screw is a Torx drive and there isn't a lot of space to get to it.
If you need to you can remove the entire fuel rail to get access.
One last thought: to depressurize the system you can remove the fuse that powers the fuel pump, is in the fuse box at the passengers feet. Start the car with the fuse removed let it idle and stall, then the rail pressure should be low. (That is what the pictures are showing as far as I can tell)
Good Luck
Paul
