Removing rear panels to get to shocks 2008 V70
volvooh
- Year and Model: '98 S70, '05&'08 V70
- Been thanked: 4 times
I've got a really annoying squeak coming from the left rear of my new to me 2008 V70. Service records indicate the shocks and bushings were replaced last summer, but I'm thinking is the old achilles heal of volvo, the dreaded strut mount. How the heck do you get the rear panels out to inspect them?
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
remove wheel and look up at top of shock, there is a two bolt plate with upper shock bushing. The lower mount is a single nut. I had to use a jack to lift the knuckle so the upper mount bolts would reach on install. It is safer to use the jack on knuckle so the bolts are stressed as you unscrew them too.
volvooh
Thank you. Don't you need to remove the interior panels in order to reach the top of the strut and the mount? That's what I am confused about, but using the jack on the knuckle is a good tip I am sure I will need.
- pierremcalpine
- Year and Model: V40 2003, V70 2010
- Has thanked: 2 times
- Been thanked: 5 times
- 23 Replies
- 6703 Views
- 1129 Views
Last post by MadeInJapan
- 28 Replies
- 4806 Views
Last post by j-dawg
- 1182 Views
- 21 Replies
- 4427 Views
Last post by erikv11
