IPD sale Volvo Parts
Did you know? 🤔
Releasing fuel lines at pump 1998 v70awd How?
ka0ren
Year and Model: V70 1998 AWD
Has thanked: 2 times
Been thanked: 0
United States of America
ka0ren
Post by ka0ren » Fri Mar 15, 2019 5:05 pm
How to release fuel lines at tank 1998 v70awd don't have a 9995666 tool
RickHaleParker
Has thanked: 3 times
Been thanked: 305 times
RickHaleParker
Re: Releasing fuel lines at pump 1998 v70awd How?
Post by RickHaleParker » Fri Mar 15, 2019 5:27 pm
You can get tools that will work at just about any Auto parts store.
9995666 is just for prying up the connector without squeezing the sleeve or cracking the connector by applying force unevenly. 9995666 pushes up on opposite sides simultaneously
You can use a small pry bar If you go gentle and work around the edge of the connector, just a nudge a little at a time. Or just nudge the connector a little on one side, then do the same on the opposite side, repeat as necessary. Baby step it.
The objective is to push the connector up evenly. If you get it uneven you may crack the connector or bend the sleeve.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
jimmy57
Been thanked: 149 times
jimmy57
Post by jimmy57 » Fri Mar 15, 2019 5:58 pm
Get some flat piece of metal strap 5/8 to 3/4 wide and no more than 1/8 thick but it is better if 1/16 thick. Aluminum or steel. Drill a
7 /16 hole in one end right at the end. Once drilled cut through the drilled a bit off of center towards end of the piece. Dress the end with file so the opening is 7/16 wide throughout. Now clamp in a vise 7/16 from the hole and use a hammer to beat the metal strap over 90 degrees. Now you have a tool with a U shaped opening on end at 90 degrees. It will slide sideways under the end fitting and pass the metal nipple on the sender/pump cap. Pull away from cap and it will slide the cuff into fitting that allows it to pass the ridge used to latch it on the nipple
These users thanked the author jimmy57 for the post:
ka0ren
ka0ren
Been thanked: 0
ka0ren
Post by ka0ren » Fri Mar 15, 2019 6:10 pm
Been trying for 3.days to release lines. Maybe I am not strong enough to pull line off.
Stuck in very small town in Ozarks. Got complete pump and sending unit. Tried making tool ,but unable to pull line off.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Fri Mar 15, 2019 6:34 pm
Any way you can set up a Mechanical advantage? ... Perhaps, block on one side as a fulcrum, then lever the tool up. It does not need to move much to release.
A picture of the tool you made might be helpful. We could see what you are working with.
These users thanked the author RickHaleParker for the post:
ka0ren
ka0ren
Been thanked: 0
ka0ren
Post by ka0ren » Fri Mar 15, 2019 7:32 pm
Thanks for all the help !
Will make a new tool tomorrow and have another go at it. I think first tool was too thin. Auto parts stores had NOTHING that would get under fitting .
Thought about bending a hacksaw blade 90 degrees and cutting pump pipes at base, but would still need to extract the cut bits.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Fri Mar 15, 2019 8:00 pm
Another thread that might be useful to you.
jimmy57
jimmy57
Post by jimmy57 » Fri Mar 15, 2019 8:48 pm
I have the factory tool but have a homemade one for some fuel tnk fittings on other vehicles that I work on with larger fuel lines. SPecifically some diesels with 12mm nipple instead of 8mm. My tool is larger but made just as I described but with different width and drills. I don't think you can get the 90 defree needle nose pliers into the place needed on the 98-2000 AWD models as that cap is smaller.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Fri Mar 15, 2019 9:38 pm
He appears to be a fabricator. Hopefully the other thread will give him a clear vision of what the tool needs to do. From that he can fabricate a tool or a method that works.
Has thanked: 191 times
Been thanked: 603 times
Trinidad & Tobago
Post by abscate » Sat Mar 16, 2019 3:43 am
Picture of tool for reference
