Hey guys, I was working on replacing my ball joints today and everything was going smooth until I stripped the hex key spot on the stud for the passenger side ball joint.
I cannot tight the nut any further.
Any tips on how to get this tightened up or should I go to a shop?
Stripped Hex Stud on Ball Joint
- Has thanked: 1503 times
- Been thanked: 3817 times
Can you grab the stud with a Vice Grip (tm)
Get a good one, ie, not from Harbor Freight
- SuperHerman
- Been thanked: 207 times
Were it me I would replace the ball joint now so it doesn't bite you in the future.
That said - abscate's idea works. If you have the space you can do some grinding to get a tool on it. You can try pounding a larger torx or allen into it. Sometimes putting pressure on the it with a jack from underneath will do it.
Regardless, when it comes up again you will have to fight what you did - so I would change it out now.
You can always grind off a fastener if there is still access. Once the torque goes up and the tapers get locked up you might not even need the counterhold
- RickHaleParker
- Been thanked: 958 times
Take a Torx Bit that a almost fits the Hex and drive it into the Hex. Back it off and replace the Ball Joint.
jimmy57
- Been thanked: 320 times
Jack the car up by that control arm so the control arm is pushing up with strut spring supported weight bearing down, this will often cause enough drag to stop the stud from spinning.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Small tip, if you can still remove the nut, remove it from there then use a steel mesh sponge to clean really well all the stud threads - so the nut can turn easily when tightening it. Then try the tips mentioned above, or more simply, replace the bj (Lemforder is the genuine one)
- 1767 Views
Last post by RyanJohnRyan
- 1205 Views
