2002 Volvo S80 T6 won't drive
- SuperHerman
- Been thanked: 207 times
You most likely have a transmission issue. Do you have any lights and have you scanned for any codes? How many miles on the S80? Without codes it might be premature to say your transmission is gone - so you need to have it scanned.
Start by checking your fluid level and color. If it is low that could be the problem. As your car has the 4t65E transmission, it most likely has a serious issue. See this site and check on your symptoms for possible causes. http://www.tripleedgeperformance.com/4T ... blems.html
Based on your description, but not knowing your mileage and location (lots of hills in your CA location would cause quicker wear), I would guess your filter is full of crud. Maybe a transmission filter and transmission oil replacement may solve your problems, but doubtful. Generally what follows is what is happening - on your car this may not be the case, but it is highly probable.
Basically what is happening is your transmission filter is clogged from all sorts of wear and tear. When the car is turned off some of this crud falls back down into the pan. Once the engine turns on, the transmission turns on and the transmission oil pump starts to suck up fluid and all the crud. This then blocks the screen/filter from passing fluid to the valve body and related - no pressure means no movement. Turn it off and the crud falls back down - turn it on and it gets sucked back up. For those short moments of movement the filter lets enough fluid to pass through to create pressure to move the car - then it clogs up all the way and no more movement.
Usually this is an indication of transmission rebuild time. Fortunately the 4T65E is found in countless cars and a rebuild can be done fairly cheap, under $3,000 with a nice warranty. If you are handy you can take it on yourself. There are rights ups on the forum, but it is not an easy process.
- SuperHerman
What type of scanner are you using and does it read transmission codes?
Your dash is telling you you have a transmission issue, with a correct scanner you will know more what the issue is causing the light.
Have you checked your transmission fluid?
- 5048 Views
Last post by jimmy57
- 1138 Views
Last post by 1volvo1
- 1321 Views
Last post by Peteh1
- 4159 Views
Last post by lalevol
- 1363 Views
Last post by SLED-MAINE
