Lost Key
golk75
Year and Model: 2005
Lost Key
Post by golk75 »
Hello all, Im new to volvo and to this forum.
question:
i have a 2006 XC90 with blown motor and a 2005 XC90 that i lost the key to, can i swap the ignition switch and ECU from 2006 XC90 to 2005 XC90 and make it work?
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
Yes, but it hard way. There are couple additional program procedures except key.
Much easier to program new key.
What city are you locate?
golk75
Post by golk75 »
near Yosemite
golk75
Post by golk75 »
I already swapped all components but 2005 XC90 still says "Start Prevented"
yagger
Post by yagger »
In this case need to synchronize your modules and key.
You can remove your CEM, ECM and sent to some service with your key.
golk75
Post by golk75 »
if the CEM (Central Electronic Module) is part of the inmobiliser system then i should be able to just swap them and it should all work right?
yagger
Post by yagger »
Sorry, I cannot understand what do you mean.
golk75
Post by golk75 »
i have the original CEM that was part of the ECM and key, should i install that CEM on the 2005 and that will be the missing part i need to get the 2005 to start?
Has thanked: 1511 times
Been thanked: 3827 times
In theory a key , ECU, and CEM should work as a triplet if moved from car to car.
My guess is they won’t though.
Jimmy might know this definitively
golk75
Post by golk75 »
well, It kind of did. car now cranks but i now get the "immobilizer see manual" message
