1998 volvo V90 engine swap
jimjimmyjim
Year and Model: 1998 V90
Post by jimjimmyjim »
i just bought a '98 V90 with 280,000 miles. it was garaged and the owner was diligent with maintenance but its a worn out engine and needs to be replaced (no compression at all in 5 cyl.). does anyone know what other years and models of Volvos used the 6304S engine.? from my initial research, it's a 20hr job for an engine swap. id like to use a low milage engine that that can fit with the least fuss. thanking you in advance for any information.
Has thanked: 1613 times
Been thanked: 4077 times
jimjimmyjim wrote: 22 Mar 2019, 09:36 i just bought a '98 V90 with 280,000 miles.
Which year and model again, please?
Unless there is a GEN 1 version of the V90 from another market, Im confused.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
96 to 98 exact match. 95 has some differences in ECT and instrument cluster coolant temp sensors and EGR. 92-94 have a different HP and torque so there is likely a cam lift or other changes that could cause some issues.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
'95 was still 960 but face lifted 960(s,v90 look).
Rebadging from 960 to s,v90 was done from '96 to '98 including '98 as a last production year.
'92-'94 900 series were totally different looking cars.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
misha wrote: 22 Mar 2019, 14:28 '95 was still 960 but face lifted 960(s,v90 look).
Actually 97 1/2 and 98 were badged as 90 series earlier built 97 year were still badged 960 at least here in the States. Nice interior upgrade and increased ac btu were the most notable change in the S/V90 over the 960 badged cars. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
misha
Post by misha »
EU market cars had re-badging a bit earlier.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
To answer the question I believe the 1995 onward engines will be a match. Strictly speaking if you swap out the sensors with your own on a 1995 you should be fine.
The notable difference is that they increased the timing belt width to 28mm (up from 25mm in the 1994 model) and associated pulleys and tensioners.
I had researched all of this when I owned a 1993 960 with a skinny 23mm timing belt (back then jimmy57 rescued me when I put the cam sensor plate in backwards and it wouldn't start)
