IPD sale Volvo Parts
Did you know? 🤔
1998 volvo V90 engine swap
jimjimmyjim
Year and Model: 1998 V90
Has thanked: 0
Been thanked: 0
United States of America
jimjimmyjim
Post by jimjimmyjim » Fri Mar 22, 2019 9:36 am
i just bought a '98 V90 with 280,000 miles. it was garaged and the owner was diligent with maintenance but its a worn out engine and needs to be replaced (no compression at all in 5 cyl.). does anyone know what other years and models of Volvos used the 6304S engine.? from my initial research, it's a 20hr job for an engine swap. id like to use a low milage engine that that can fit with the least fuss. thanking you in advance for any information.
Has thanked: 166 times
Been thanked: 486 times
Trinidad & Tobago
Re: 1998 volvo V90 engine swap
Post by abscate » Fri Mar 22, 2019 11:00 am
Which year and model again, please?
Unless there is a GEN 1 version of the V90 from another market, Im confused.
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
jimmy57
Has thanked: 1 time
Been thanked: 127 times
jimmy57
Post by jimmy57 » Fri Mar 22, 2019 11:32 am
96 to 98 exact match. 95 has some differences in ECT and instrument cluster coolant temp sensors and EGR. 92-94 have a different HP and torque so there is likely a cam lift or other changes that could cause some issues.
misha
Has thanked: 23 times
Been thanked: 82 times
Serbia
misha
Post by misha » Fri Mar 22, 2019 2:28 pm
'95 was still 960 but face lifted 960(s,v90 look).
Rebadging from 960 to s,v90 was done from '96 to '98 including '98 as a last production year.
'92-'94 900 series were totally different looking cars.
'97 850 2.5 20v /fully equipped/ Motronic 4.4 / polar white wagon
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
June
Year and Model: 2004 S80 T6
Has thanked: 173 times
Been thanked: 87 times
June
Post by June » Fri Mar 22, 2019 5:34 pm
Actually 97 1/2 and 98 were badged as 90 series earlier built 97 year were still badged 960 at least here in the States. Nice interior upgrade and increased ac btu were the most notable change in the S/V90 over the 960 badged cars. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
misha
Serbia
misha
Post by misha » Sat Mar 23, 2019 6:58 am
EU market cars had re-badging a bit earlier.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Year and Model: Lots
Has thanked: 3 times
Australia
Post by precopster » Sat Mar 23, 2019 4:20 pm
To answer the question I believe the 1995 onward engines will be a match. Strictly speaking if you swap out the sensors with your own on a 1995 you should be fine.
The notable difference is that they increased the timing belt width to 28mm (up from 25mm in the 1994 model) and associated pulleys and tensioners.
I had researched all of this when I owned a 1993 960 with a skinny 23mm timing belt (back then jimmy57 rescued me when I put the cam sensor plate in backwards and it wouldn't start)
Current cars:2002 XC70, 2001 V70 T5, 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
