Sunroof leak
cxf
Year and Model: 1996 850T
Post by cxf »
Car is a 1996 850T that I have had for a long time. A while ago it developed a sunroof leak on the drivers side. If I put one of the drive on rino ramps under the left rear tire I get no leak at all. Finally a couple of weeks ago when it was relatively warm I removed the sunroof and blew out the rear and front drain lines. After blowing out I ran several quarts of water through all the lines and everything was draining as designed. Last night and today we had rain and the leak is still there. The "gutter" that runs across the rear of the sunroof(left to right) across the car is there and appears to be working as it should. I'm stumped... any ideas anyone?
Thanks in advance
p.s. seal around the glass seems ok... not perfect
p.s.s. next idea is to grab a new sunroof panel at a p'n'p if I can find a good one
Has thanked: 2199 times
Been thanked: 1851 times
If the drains are clear then there are a few options:
1) The drains are just plastic tubes and have been known to break at each of the four corners where the drains exit.
2) If the drains are clear it is unusual for the sunroof to leak. Where is the water being found?
3) I had a similar leak and it only happened if the rain was heavy from one direction or if the car was sitting a certain way. This was eventually tracked to a leaking windshield seal.
If you can tell us where the water is being found, it may not be the windshield or sunroof.
If it is on the drivers side floor then it could be your heater core. If that is leaking you often get a sweet small and a greasy residue on the lower part of the inside of the windshield.
Finally check the drains in the windshield wiper area under the plastic cover are not blocked. If they do then they eventually drain back into the car.
cxf
Post by cxf »
Hi, thanks for the reply. The leak is around the sunroof on the drivers side. As I stated earlier drains were blown out and several quarts of water were emptied into the "gutter" for both left and right side front and back and I observed the water draining out. I am now leaning toward this being a leak from the top of the windshield and finding it's way to the area around the left side of the sunroof. Again, with the left side up on a rino ramp zero leak.
WhatAmIDoing
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
Where is the wet spot / where is the water pooling?
tysauce1986
Year and Model: 1995 850 GLT wagon 5
Has thanked: 7 times
Post by tysauce1986 »
So no resolution to this? Mine leaks when the front of the car is slightly pitched downwards. And it leaks at the center of the glass, into the light assembly, directly onto my window switches. I'm planning on cleaning the gasket really well OD and what I can easily get of the ID. then smearing a thin layer of silicone. Any thoughts?
WhatAmIDoing
tysauce1986 wrote: 23 Mar 2019, 22:07 So no resolution to this? Mine leaks when the front of the car is slightly pitched downwards. And it leaks at the center of the glass, into the light assembly, directly onto my window switches. I'm planning on cleaning the gasket really well OD and what I can easily get of the ID. then smearing a thin layer of silicone. Any thoughts?
in your case, a bead of silicone will probably do it, if it's leaking around the inside of the seal and not the outside.
Has thanked: 1609 times
Been thanked: 4065 times
I had a very slight leak after windshield replacement years ago, which I cured with a tiny application of RTV black applied under the seal, lifting it with a credit card and putting a film behind in about a 30 second operation. Worked beautifully
