Driver door speaker cutting out intermittently
clarkerussell
Year and Model: 1998 S70 GLT
Has thanked: 20 times
Been thanked: 4 times
Post by clarkerussell »
Hey guys,
My driver door speaker on my 1998 S70 is cutting out intermittently. The tweeter is fine, but the woofer cuts out. I have the factory head unit and I added the behind the dash factory amp a few years ago. The wiring on the speaker seems OK.
Does the amp send a separate signal to the tweeter and the woofer, or is the crossover built into the tweeter? Is it possibly an issue with the amp? I can't seem to track this down...
Thanks guys!
Has thanked: 2200 times
Been thanked: 1852 times
If you don't have access to a spare, you could swap the passenger side and drivers side speakers and see if the problem transfers.
If it doesn't then you may have to have the fun of looking at the wiring into the door. I have had random wires break inside the wiring harness just inside the door where the harness disconnects from the door post.
clarkerussell
So does the wiring go from the radio/amp to the woofer and then the tweeter, or is it discrete wiring to each from the radio/amp?
If it's a single, does it go to the tweeter first, or the woofer?
bill d cat
Year and Model: 1998 V70 T5M
Been thanked: 7 times
Post by bill d cat »
My 2 front door speakers were cutting in and out intermittently. Both of them, leading to my confusion. It wasn't the radio or the wiring, it was the 2 front speakers. 20 years was about it for them.
If you have another speaker around, suggest testing with it.
viewtopic.php?f=33&t=57976
viewtopic.php?f=1&t=86624&hilit=Classic
'98 V70 T5 232K mi., 5-speed manual, 3rd evaporator, 3rd windshield, 7th remote shell, heated velour seats, factory HD suspension, IPD stabilizer bar, Volvo strut tower brace and skidplate, XC grill, E-Codes, V-1, JB Weld, Duck Tape, zip-ties, Mobil-1 since new. Goal: MADE IT to the MOON! (was 221,524 miles at perigee November 14, 2016.)
Has thanked: 1610 times
Been thanked: 4065 times
bill d cat wrote: 23 Mar 2019, 18:35 My 2 front door speakers were cutting in and out intermittently. Both of them, leading to my confusion. It wasn't the radio or the wiring, it was the 2 front speakers. 20 years was about it for them.
When are you going to hit the Moon, Bill???
