Swapping Remote Module
I'm in the process of parting out a 1998 V70r. Can I remove the remote module and install it into my 1998 S70? I didn't get a remote with the S70 and the trunk lock is different than the ignition so I am considering swapping out the ignition and other locks from the R too.
- Has thanked: 311 times
- Been thanked: 817 times
Yes, plug in the module and if you have a working remote from the V70 to go with it, it will work in the 98 S70. Programming the remotes requires a trip to the dealer on a 98.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
If your ‘98 S70 already has a remote module in the dash,
and you’re only missing the 9166200 fob, there should’t be
any reason to change the receiver module. Just get a hold
of a functional fob and have it programmed into the car.
Bumping this... I've heard different stories on this. Is it really necessary to go to do the dealer to program remotes on a 1998 S70? Volvo has tried to do the procedure on an acquaintances' 98 S70 but they said it didn't work for what-ever reason.erikv11 wrote: 23 Mar 2019, 23:12 Yes, plug in the module and if you have a working remote from the V70 to go with it, it will work in the 98 S70. Programming the remotes requires a trip to the dealer on a 98.
- Year and Model: Many Volvos
- Been thanked: 76 times
It isn't as elaborate a procedure as it is on the '99+ versions but you do need the Volvo Scan Tool or the equivalent to mate the remote on a '98. The 850s are totally DIY and the '99+ are a software download. The '98 is in between but I think my local shop charged me maybe $10.00 to do it on my daughter's old S70.
- 2215 Views
Last post by yagger
- 636 Views
Last post by harryhendo
- 11 Replies
- 5118 Views
Last post by SwedishMadeFunBrick
- 1375 Views
Last post by ber5ien
- 11 Replies
- 7061 Views
Last post by Vovoroom
