Engine reving when brake pedal is applied?
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 157 times
- Been thanked: 6 times
Just wondered if anyone might know the answer to this problem when I come to a stop light or stop sign and apply the brake the engine for some unknown reason revs up to say 3000 rpm's or higher and won't drop down unless I throw the car into neutral. Any thoughts?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
How many miles on it?
Being a 2002 I would thing first throttle body module. But may be also a vacuum issue ?
Have a look at the brake vacuum switch and pump - it sounds like it is sucking in excess air and fooling the ECM to rev up. Get this fixed, thats dangerous from both an untended acceleration and reduced braking performance issue - that can't end well.
Mr. Detail
oragex, she has 153k miles on her.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Sounds like you've got one heck of a leaking brake booster. Try disconnecting the vacuum hose from the booster and plug the hose. Then see if the problem persists. Be careful if you drive the car with the hose disconnected as you will have to apply MUCH MORE foot pressure on the pedal to stop.
- 12 Replies
- 4019 Views
Last post by JRL
- 49 Replies
- 7419 Views
Last post by WhatAmIDoing
- 1399 Views
Last post by jking4020
- 725 Views
Last post by xc90surfer3
- 11 Replies
- 6431 Views
Last post by lostmyVcardXC
