Did you know? 🤔
06 s40 non turbo, engine struggle while on gear
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
Tillan
Year and Model: 2006 s40
Has thanked: 0
Been thanked: 0
Canada
Tillan
Post by Tillan » Fri Mar 29, 2019 2:15 pm
Hello, I have 2006 volvo s40 and recently the car has been acting up since the temperature has gone up to the plus this spring. Sometimes when I start the car it chokes and dies the first try and the second try everything is good and starts and runs properly. But today when I started the car, usually let it idle for 5 minutes before I start to drive. When I put the car in reverse the car died like 4 times and the 5th time it didn't die. It felt like the engine choked and died while the car shakes and vibrates. Checked codes and found these 3, p0089, p0192 and p0026. I also have a video of exactly what happens except, the car didn't die in the video. Please help!
RickHaleParker
Has thanked: 3 times
Been thanked: 548 times
United States of America
RickHaleParker
Re: 06 s40 non turbo, engine struggle while on gear
Post by RickHaleParker » Sat Mar 30, 2019 6:01 am
P0192 is the Fuel pressure Sensor or the wiring to the Fuel pressure Sensor.
P0089 is Fuel pressure, Faulty signal which can be tripped by P0192.
1. Check your Fuel Pressure.
2. Check the wiring and clean the contacts to the fuel sensor.
3. If 1 & 2 are not the problem, replace the Fuel pressure Sensor with a Genuine Volvo Fuel pressure Sensor or a OEM Fuel pressure Sensor.
P0026 is Slow Camshaft position control.
What is the condition of the motor oil?
Correct type of motor oil?
When was the last time the motor oil and oil filter was changed?
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
