2.9 idling issues
Tylerhagerdorn
- Year and Model: 2000 S80 2.9
I recently purchased a 2000 S80 2.9 with extensive impressive service history and records. Starts up and runs amazing. Then when it gets warmed up, issues arise. When I bought it, I scanned the engine light and got p1330 and p0340. Cleared them, and the p1330 came back. When its warm, at idle it drops to around 500 rpms and will rise back up. It constantly does this. Has not died on me while driving. I took the cvvt solenoid off and deep cleaned it. Didnt look bad or gummed up at all, and oil is full. Bought a new gasket at the Volvo dealer, and also replaced the plugs as they were horrible Bosch Coopers that looked like they had been in there forever but they havent been. I warmed it up, drove it and all seemed great. Then parked it and let it run at idle. The surging and dropping in idle came back and no code has popped back up yet. It has had the etm cleaned and repaired before at the Volvo dealer and the ecm was also fixed as well. I'm stumped and dont want to keep dropping money into it. Anyone have suggestions? Timing belt is still in great shape and doesn't have many miles on it.
Hello.Tylerhagerdorn wrote: 02 Apr 2019, 12:45 I recently purchased a 2000 S80 2.9 with extensive impressive service history and records. Starts up and runs amazing. Then when it gets warmed up, issues arise. When I bought it, I scanned the engine light and got p1330 and p0340. Cleared them, and the p1330 came back. When its warm, at idle it drops to around 500 rpms and will rise back up. It constantly does this. Has not died on me while driving. I took the cvvt solenoid off and deep cleaned it. Didnt look bad or gummed up at all, and oil is full. Bought a new gasket at the Volvo dealer, and also replaced the plugs as they were horrible Bosch Coopers that looked like they had been in there forever but they havent been. I warmed it up, drove it and all seemed great. Then parked it and let it run at idle. The surging and dropping in idle came back and no code has popped back up yet. It has had the etm cleaned and repaired before at the Volvo dealer and the ecm was also fixed as well. I'm stumped and dont want to keep dropping money into it. Anyone have suggestions? Timing belt is still in great shape and doesn't have many miles on it.
Did You check https://www.matthewsvolvosite.com/volvo ... ule-fiasco
Volvo S80
- Year and Model: 1999
- Has thanked: 7 times
- Been thanked: 2 times
From my experience things that you should check are:
Air filter, fuel filter, spark plugs, spark plug wires, ignition coils,clogged fuel system, fuel injector o-rings, fuel injectors, throttle module, o2 sensors, pcv clogged.
I hope you will fix it, S80 is a great car when fine but when it start to act they are not an easy or cheap car to fix.
- 1140 Views
Last post by father ted
- 20 Replies
- 3036 Views
Last post by 850 LPT
- 427 Views
Last post by misha
- 1392 Views
Last post by 5potoilburner
- 696 Views
Last post by bmdubya1198
