Did you know? 🤔
strut lower nut part number
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
ogatrulle
Year and Model: xc90 2008
Has thanked: 1 time
Been thanked: 6 times
United States of America
ogatrulle
Post by ogatrulle » Thu Apr 04, 2019 8:45 am
2008 xc90 3.2 FWD, chassis 579089
Anyone have wisdom to share regarding the part number/availability of the two nuts that go at the bottom of the struts?
VIDA says: use new screws and new nuts where the strut connects to the knuckle. In the following parts diagram (also VIDA), they show two possible part numbers for the nuts, depending on chassis. My chassis is after 352988, so this says M14x19.2 987938.
However, there is confusion in the various online parts house listings. Some indicate 987938 is equivalent to or superseded by 985932 which is a shorter nut (M14x15.9). Almost no parts houses seem to carry the longer 987938 at all.
Why? It seems unwise to me to use a shorter nut for this critical application. Any insights?
2006 v70 2.5T; 2008 xc90 3.2
RickHaleParker
Has thanked: 3 times
Been thanked: 544 times
RickHaleParker
Re: strut lower nut part number
Post by RickHaleParker » Thu Apr 04, 2019 9:29 am
The bulk of the forces are vertically not horizontal.
Horizontal forces are checked by the metal bracket.
The nut just keeps the load bearing bolt in place.
Use the 985932.
You would not see the change unless a Volvo Mechanical engineer did the math and signed off on it.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
ggleavitt
Year and Model: XC90 05-2.5T, 08-V8S
Has thanked: 0
Been thanked: 60 times
ggleavitt
Post by ggleavitt » Thu Apr 04, 2019 11:51 am
See photo- 985932 on the left, two flavors of 987938 on the right.
StrutKnuckleNut XC90_985932_987938.jpg (200.07 KiB) Viewed 180 times
The 3.3mm difference is the integrated washer I suspect. Up to today I was convinced that both nut versions were required, based on chassis number, and I have been using the 985932 on my '05 and the 987938 on my '08 as a "rule" (I have some stock and replace when doing any major work).
Curious again about the differences in reading this post, I did some looking around on various Volvo reseller web sites, including the Volvo main parts site- https://usparts.volvocars.com/p/Volvo__ ... 87938.html and oddly enough, the 987938 seems to revert to the 985932. Couple other non-Volvo sales sites (IPD as one) note the same thing.
Go figure.
Edit 4/4/19- typos, reverts (not superceded).
2005 2.5T AWD-200k
2008 V8 AWD Sport-130k
wanderdüne
Year and Model: 2004, 2006 XC90 2.5T
Has thanked: 4 times
Been thanked: 39 times
wanderdüne
Post by wanderdüne » Thu Apr 04, 2019 8:46 pm
I just replaced the struts on both my 2003 and 2004, and the nuts that came off were the 985932 style. I believe them to have been the original nuts and screws on both vehicles. I just went out and measured them, and they are more like 13.9mm, maybe 14. Certainly they are not 15.9.
I replaced them all with the 985660 (similar to the 987938) that I got from FCP (their recommendation), which is the nut from the vertical screw on the front control arm. When I did them, I lined up the nut part to the old (985932) and they were identical heights, with the captive washer adding some height. Since I was replacing eight screws between the two vehicles, I used the 982870 that's from the same vintage XC70. It's the same bolt except for the tapered end on the 982869, the thread length is identical. Torque value is 105Nm +60* for the XC70 vs 105Nm+ 75* on the XC90 spec, so I felt pretty comfortable using them (I tightened to the higher XC90 spec). The cost difference in the screws for eight pieces (about $60 difference) was enough for me to get the 982870 instead of the 966363. Not a recommendation, just what I did.
I'm curious as to the height specs of 15.9 and 19.2? because the nuts I took off both vehicles appeared to be original, as did the struts and they are, again, not near that height.
