Did you know? 🤔
Believe the dipstick or manual for correct oil level?
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
vmaxmike
Year and Model: 06 S60R, 07 XC90 3.2
Has thanked: 0
Been thanked: 0
United States of America
vmaxmike
Post by vmaxmike » Sat Apr 06, 2019 8:53 pm
Owners manual says 7.7 US quarts including filter replacement is the engine oil capacity (volume) for my 07 xc90 with 3.2 yet after an oil and filter change, the level is still slightly BELOW the L mark after adding 8 quarts! I've had this car for 7 years and could never figure this out. I end up adding maybe another half quart to bring level between the marks or total 9 quarts to F but always wondered #1: Why does manual not indicate proper amount or #2: Is the dip stick not the proper length? or #3: why does this engine need so much oil in the first place?
SuperHerman
Has thanked: 0
Been thanked: 157 times
SuperHerman
Re: Believe the dipstick or manual for correct oil level?
Post by SuperHerman » Mon Apr 08, 2019 7:02 pm
Really tough call on how much to put in as too much could cause problems and too little could cause the same. No way to know what is the correct amount, other than the factory manual, other than to pull the pan and actually measure.
I have read about after market and related models using different length dip sticks. Maybe yours was changed at one point.
Oil both lubricates and cools. The more oil the better for these reasons, plus it breaks down faster if it has less oil.
I had an old VW bug which had a 3 quart capacity. It was an air cooled engine, meaning the oil had a huge cooling function. Down a quart was not good.
jimmy57
Has thanked: 4 times
Been thanked: 239 times
jimmy57
Post by jimmy57 » Mon Apr 08, 2019 8:57 pm
The european countries pushed 12000 mile oil change intervals at one time. If you go that long you dilute contaminants with more oil and make them less harmful.
That still sounds like more than I ever pour into a 3.2. I think 8 1/4 is all I have ever put in them. DOes the disptick show the same level is you turn 1/2 turn and try it that way? Regardless, it is probably fine to have almost 9 if it doesn't use oil with that much.
Roger_850T
Year and Model: 854T 1995
Has thanked: 0
Been thanked: 14 times
Roger_850T
Post by Roger_850T » Tue Apr 09, 2019 8:02 pm
I find the manuals are generally pretty spot-on, so this seems suspicious. I'd start by verifying it's the correct dipstick, (volvo p/n should be stamped on it,) then I'd inspect that the dipstick tube is properly seated and inserted all the way.
Roger
'05 XC90 V8 140k
'95 854T 310k
'02 V70 159k
'03 S80 111k (crashed)
'93 945T 217k (gone to be parted out)
'87 245 300k+ sold, still going
'84 264 Diesel, RIP at 160k
'78 242 manual everything.
'73 P1800ES, fun until the rust set in...
vmaxmike
Has thanked: 0
Been thanked: 0
vmaxmike
Post by vmaxmike » Wed Apr 10, 2019 7:07 am
I think I'm somewhere between 8 1/4 and 8 1/2 now and level is just about full. Sometimes the level will show higher on one side of the dipstick than on the other which is another oddity. I usually let the engine cool at least 10 min before checking level.
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 23 times
Been thanked: 42 times
pgill
Post by pgill » Sun Apr 14, 2019 6:26 pm
Mike,
This may help
This engine type is very sensitive to overfilling because it is hard to check the oil level
with the dipstick in an easy way. This is because the engine oil needs time to settle in
the oil sump and also because the dipstick can be turned around causing the indicated
level to be different. The car must be parked on level ground when measuring the oil.
The engine should be driven at normal operating temperature on the road (not idling) for
30 minutes. The engine must then be left for 15 minutes before noting the oil level.
It is also important to note that the dipstick changed in Model Year (MY) 2007 and MY
2011 vehicles. The different part numbers (P/N) for oil dipsticks have chassis breaks in
the VIDA parts catalog. Refer to the catalog to identify the correct P/N. For vehicles
with engine code 94 see page 3 concerning the dipstick. When refilling the engine
with oil its imperative that the correct fill amount be used.
http://australiancar.reviews/_pdfs/Volv ... 201204.pdf
Also the Anti Drain Valve in the bottom of the oil filter housing is a known failure point. (it failed on both of my 3.2's)
When the anti drain valve fails the oil pressure drops (when running) and the oil sump level increases when the engine is switched off.
Here is a write up I did about my Land Rover (with the Volvo 3.2 engine)
http://www.freel2.com/forum/topic33006.html
Good Luck
Paul
Has thanked: 318 times
Been thanked: 986 times
Trinidad & Tobago
Post by abscate » Mon Apr 15, 2019 4:59 am
A difference between 7,8,9 liters probably isn’t important. I’m guessing the pistons are cooled by oil jets and not splash , so The last liter of oil just sits in the sump
I run older, high mileage cars so I check oil levels at least monthly and weekly on the 30k a year heavy use T5
Anywhere between the marks on the dipstick is fine, no need to obsess about having it at Full, no benefit
Link To Volvo Glossary
vmaxmike
Has thanked: 0
Been thanked: 0
vmaxmike
Post by vmaxmike » Mon Apr 15, 2019 8:27 am
I just changed the oil and didn't notice any issue with that drain valve inside the housing but will pay closer attention next time now that i know those can fail. At 12 yrs old and 166k, it still runs good and very little to no oil consumption. This is great info, thanks
Trinidad & Tobago
Post by abscate » Mon Apr 15, 2019 9:44 am
Im running non Euro spec synthetic in all the cars and Blackstone is telling me my oil is still like new at 7500 miles - the 15000 mile interval isnt crazy, many driving styles and engines in good shape can give oil life in this range.
The ONLY way to tell is by analysis, not anecdote from Uncle Joe, 'Looking at how black it is' or sludge levels. Test it if you want to know and not Guess.
Roger_850T
Has thanked: 0
Roger_850T
Post by Roger_850T » Sun May 05, 2019 5:01 pm
Did you ever confirm if you have the right dipstick? Looking in VIDA, I see there are 3 different dipsticks, depending on your chassis number. (Chassis number is the last 6 digits of your VIN...)
Dipstick 30788016 CH -418239
Dipstick 31251037 CH 418240-568000
Dipstick 31316562 CH 568001-
Hope this helps!
Roger
'05 XC90 V8 140k
'95 854T 310k
'02 V70 159k
