Did you know? 🤔
Fresh gas smell revisited. Topic is solved
rguzz
Year and Model: 1996 850 turbo
Has thanked: 0
Been thanked: 5 times
rguzz
Post by rguzz » Sun Apr 07, 2019 10:43 am
Subject is 96 855t, 250+ k miles. Just had injectors cleaned (Mr. Injector), replaced FPR with new Bosch oem, haven't changed the filter yet, have no idea how old it is. Strong smell of raw gas ? getting worse? if you stand mid way down the vehicle on the passenger side. It's worse after a run and the system is pressured up. Smells ok at the fuel rail. I've been under it a few times no overt leaks, some smell around the gas tank which has been there for years, lines to tank are all original. How best to pinpoint the problem origin? Smoke the system somehow? I might add it still appears to run a bit rich also, smells that way, exhaust pipe is black. Car runs like a top overall, just back from a 1500k trip. Are these issues related? Next step? Reluctant to tear fuel system/lines apart without a direction to go in. Thanks!
WhatAmIDoing
Year and Model: 1998 S70 T5M
Has thanked: 66 times
Been thanked: 56 times
Canada
WhatAmIDoing
Re: Fresh gas smell revisited.
Post by WhatAmIDoing » Sun Apr 07, 2019 1:35 pm
Gas smell without a leak. I would investigate the evap system first, since its job is to collect fuel vapor and get it to the engine for combustion. If lines were never touched, they're probably dust now.
'98 S70 T5M - 282,000+mi - forever a project
'99 S70 "AWD" - 220,000+mi - part out :cry:
Knows enough to be dangerous :wink:
Sommerfeldt
Year and Model: 1996 850 T5
Has thanked: 55 times
Been thanked: 36 times
Norway
Sommerfeldt
Post by Sommerfeldt » Sun Apr 07, 2019 2:33 pm
+1 on WhatAmIDoing's suggestion. My evap system was pretty much tatters and rags when I got the car, running rich with fuel smell here and there. Took me quite a while to figure out, but when I replace the valve and the lines, it cleared up.
- S
'96 855 T5, R bumper and spoiler, Koni Yellows & blue H&R springs all 'round.
rguzz
Has thanked: 0
rguzz
Post by rguzz » Sun Apr 07, 2019 2:47 pm
Did a little searching. Still not clear on what specifically to look at first. Would prefer that to be the simplest things, of course, but am prepared for bigger things to come. Sounds likely to be in the evap system somewhere, though. And car does runs rich. First, path of least resistance thing to look at? I did find a post 2010 from Ozark Lee suggesting a place to start might be the lines @ the charcoal canister, so maybe that's what I'll do? For what it's worth strongest gas odor is in vicinity of the fuel filter, smells ok at the canister.
RickHaleParker
Has thanked: 3 times
Been thanked: 548 times
United States of America
RickHaleParker
Post by RickHaleParker » Sun Apr 07, 2019 8:51 pm
Run the fuel tank low, Tracer Dye the Fuel system, take the car out for a long run then go looking for the source with a UV light.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
rguzz
Has thanked: 0
rguzz
Post by rguzz » Tue Apr 09, 2019 7:07 pm
First finding is two broken lines to the rollover valve, so I will replace fuel filter, repair the broken lines. This is vicinity of strongest gas odor. Next I will look @ the fuel pump lines through the hatch in the back. Go from there. Thanks!
ZionXIX
Has thanked: 9 times
Been thanked: 41 times
ZionXIX
Post by ZionXIX » Tue Apr 09, 2019 11:17 pm
When I replaced my fuel filter I found both of those hoses to the roll over valve to be shredded.
Has thanked: 318 times
Been thanked: 986 times
Trinidad & Tobago
Post by abscate » Wed Apr 10, 2019 1:12 am
I bet you will find the odour gone with the Evap service. Try it for a week before you tear into fuel lines
Link To Volvo Glossary
rguzz
Has thanked: 0
rguzz
Re: Fresh gas smell revisited.  Topic is solved
Post by rguzz » Thu Apr 11, 2019 8:33 pm
Yes! After repairing the two broken rubber lines @ the rollover valve, (they were just hanging there), I replaced the fuel filter and voila! all is well, no gas smell, no running rich smell. A little surprised, no CEL ever. No reason to go further at this point. For now I will enjoy odor free fill ups and an odor free garage. Thanks!
Sommerfeldt
Norway
Sommerfeldt
Post by Sommerfeldt » Fri Apr 12, 2019 4:01 am
Excellent update. Well done! :)
- S
