Did you know? 🤔
P0102 on 2001 2.9L S80 - Rough idle, cruise control doesn't engage, rough gear changes
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
dav54123
Year and Model: Volvo 2001 s80
Has thanked: 0
Been thanked: 0
United States of America
dav54123
Post by dav54123 » Sun Apr 07, 2019 11:51 am
Hello all,
I've had my s80 for coming up on 4 years this may and it has been great. It is very high miles (225k) but has driven like a dream up until a couple days ago.
I got a check engine light and a P0102 code ("mass or volume airflow a circuit low") on an OBDII scanner. I cleaned the MAF sensor with some electronic cleaner and knocked out the air filter. The air filter had very little detritus in it, but the edges of the filter did seem to be a bit wet (???). It hasn't rained much recently and I haven't driven through any puddles recently (If i went through any water it would've been over 1-2 weeks ago).
These are the symptoms I'm having:
-Rough idle, can't maintain any specific RPM
-Car still runs, but gear shifts can be erratic or jumpy
-Sometimes the gas pedal becomes unresponsive until I restart the car
-Cruise control has stopped working altogether - the "cruise" text doesn't pop up on the speedometer anymore
-RPM fluctuates when coasting on road
Would replacing the MAF sensor solve this code? Any ideas of other stuff to try?
Thank you in advance!
RickHaleParker
Has thanked: 3 times
Been thanked: 544 times
RickHaleParker
Re: P0102 on 2001 2.9L S80 - Rough idle, cruise control doesn't engage, rough gear changes
Post by RickHaleParker » Sun Apr 07, 2019 12:04 pm
P0102 = ECM-1300 Mass air flow (MAF) sensor. Flow too low.
1. Air leakage
2. Contact resistance
3. Short-circuit to ground in the signal cable
4. Open-circuit in signal cable
5. Open-circuit in power supply cable
6. Defective sensor
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
TivoliBG
Year and Model: Volvo 1999 S80
Has thanked: 0
Been thanked: 0
Sweden
TivoliBG
Post by TivoliBG » Thu May 16, 2019 9:26 pm
Try to disconnect The MAF sensor and see IF there is any differense
DeadEric
Year and Model: 1996 850 Turbo
Has thanked: 2 times
Been thanked: 12 times
DeadEric
Post by DeadEric » Thu May 16, 2019 9:51 pm
MAF flow codes rarely point to a MAF failure in my experience.
The computer is looking at the MAF data and seeing the other sensors saying the MAF can't be right but nothing else is measuring air flow.
7 of 10 times it's a vaccum leak. 2.5 of 10 it's a lazy O2 sensor. Point 5 of 10 it's a bad MAF.
