IPD sale Volvo Parts
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
2004 T5 C70 aerial issue ( not the normal issue ) Topic is solved
NathansC70
Year and Model: 2004 c7p
Has thanked: 0
Been thanked: 0
Great Britain
NathansC70
Post by NathansC70 » Sun Apr 07, 2019 2:05 pm
I have a Volvo C70 convertible and theaerial wont go up. I have removed the aerial checked the mechanism nothing wrong with it and with a power supply goes up and down fine. I even purchased another aerial second hand and put in car, still no joy. So definitely not the aerial itself. The stereo I have is a sc-901 which has always worked perfectly? Anyone had this issue. Is there a hidden fuse?
NathansC70
Has thanked: 0
Been thanked: 0
Great Britain
NathansC70
Re: 2004 T5 C70 aerial issue ( not the normal issue )
Post by NathansC70 » Sun Apr 14, 2019 1:12 pm
Wow no help whatsoever, so if it’s out of the normal issue no ones got a clue or suggestion. Only other forum I have ever found this with is the Civic boys, there solution is take it to the dealer!
RickHaleParker
Has thanked: 3 times
Been thanked: 299 times
United States of America
RickHaleParker
Post by RickHaleParker » Sun Apr 14, 2019 2:09 pm
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
1997 S90, B6304S, AW30-42, Bosch Motronic 4.4 - Sold
NathansC70
Has thanked: 0
Been thanked: 0
Great Britain
NathansC70
Post by NathansC70 » Sun Apr 14, 2019 2:32 pm
Cheers rick I think checking the grounds is the first port of call, then the relays
NathansC70
Has thanked: 0
Been thanked: 0
Great Britain
NathansC70
Post by NathansC70 » Sun Apr 14, 2019 2:43 pm
Do you know which relays numbers they are?
NathansC70
Has thanked: 0
Been thanked: 0
Great Britain
NathansC70
Post by NathansC70 » Sun Apr 14, 2019 2:56 pm
antenna inhibitor relay ? Any ideas which one this is?
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 178 times
Been thanked: 539 times
Trinidad & Tobago
Post by abscate » Sun Apr 14, 2019 3:55 pm
Those relays are labeled as being in the electronics unit on left side of engine compartment
This might be mirrored for RHD though.
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
RickHaleParker
RickHaleParker
Post by RickHaleParker » Sun Apr 14, 2019 4:23 pm
That is all I could find on the subject.
Has thanked: 6 times
Been thanked: 128 times
Canada
Post by scot850 » Sun Apr 14, 2019 5:18 pm
On the Volvo aerials there is a single yellow (?) wire on a connector on the back of the radio. Check the wire is not broken or the connector has been accidentally removed. If I recall correctly this is the wire feeding signal to the aerial.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
RickHaleParker
RickHaleParker
Post by RickHaleParker » Sun Apr 14, 2019 6:50 pm
The schematic above is from Mitchell. I think Mitchell got it wrong.
This from Volvo TP3943292 which, according to Volvo Tech Info, Cover 2000 S70, 2000 V70 and 2000 - 2004 C70.
Looks like Scot850's suggestion is the first port of call.
You might try pulling the SC901 out, disconnect the harness, for voltage on Power Antenna motor wire.
