Did you know? 🤔
2006 V70 2.5t power steering rack leaking slowly
2001 - 2007 XC-70
Rvolvos
Year and Model: 2006 xc70
Has thanked: 35 times
Been thanked: 3 times
United States of America
Rvolvos
Post by Rvolvos » Sun Apr 07, 2019 8:12 pm
The power steering rack of our 2006 V70 is slowly leaking, splash guard wet. I added some UV Dye to power steering fluid and was able to find the source. Looks like it is leaking from the back of the rack where the steel lines are inserted into the rack. Gold color in the attached picture. Not the lines from and to the steering pump.
Went to the dealer and they where able to find the exploded view of a rack listing these o-rings. But the rack in the picture showed screw in type fittings and not the style I have. This was the only thing available to order.
PN 969092& 969093. Are these the right size for all racks? Would like to before pulling it apart.
Thanks!
2006 XC70 2.5T 190k
2006 V70 2.5T 152k
2011 C30 T5 AW55-50SN 99k
2011 C30 T5 M66 66k
Has thanked: 0
Been thanked: 131 times
Re: 2006 V70 2.5t power steering rack leaking slowly
Post by cn90 » Mon Apr 08, 2019 10:01 pm
How many miles?
These leaks are slow leak. I guess you can wait a bit before replacing the pipes.
Rvolvos
Rvolvos
Post by Rvolvos » Mon Apr 08, 2019 11:37 pm
143 k miles. It was leaking a bit but lately more.
Learned today about the oil pipe kit.
http://www.skandix.de/en/spare-parts/su ... 89799bc51e
And the o rings only, on the gearbox side 955978
Thanks to Fcpeuro, but they do not sell the parts.
Steering acts a bit erratic too during sharp corners. Was thinking maybe due to the leak pressure loss.
2006 XC70 2.5T 190k
2006 V70 2.5T 152k
2011 C30 T5 M66 66k
Rvolvos
Rvolvos
Post by Rvolvos » Tue Apr 16, 2019 8:27 am
Went ahead and ordered pn 30776289.
Refer to the attached picture for compatible models.
2006 XC70 2.5T 190k
2006 V70 2.5T 152k
2011 C30 T5 M66 66k
oragex
Year and Model: S60 2003
Has thanked: 95 times
Been thanked: 266 times
Canada
oragex
Post by oragex » Tue Apr 16, 2019 8:37 am
Is it the complete lines ? If you need some tips, this is a good DIY video
Rvolvos
Rvolvos
Post by Rvolvos » Tue Apr 16, 2019 10:36 am
Yes complete pipe kit with all 4 O-rings.
O-rings on side (screw-in side) are not available for purchase. Will let you know after arrival of the kit.
Thanks for the link! I hope I can replace these without removing the rack.
2006 XC70 2.5T 190k
2006 V70 2.5T 152k
2011 C30 T5 M66 66k
Rvolvos
Rvolvos
Post by Rvolvos » Sun May 26, 2019 10:35 am
It is not possible to replace these lines without having to remove the sub frame.
There is not enough room to remove the lines. I removed the brace at the bottom and the exhaust rubber mounts for visibility. And replaced only the o-rings on power steering side. Lines where still in good condition.
So far so good.
2006 XC70 2.5T 190k
2006 V70 2.5T 152k
2011 C30 T5 M66 66k
oragex
Canada
oragex
Post by oragex » Sun May 26, 2019 12:38 pm
Good fix. Wonder, were the lines the same as on your car ? Asking because the pic above is listing same numbers for 01-09 while I remember the steering rack to have been different from between 01-03 and 04-up
Rvolvos
Rvolvos
Post by Rvolvos » Sun May 26, 2019 5:31 pm
They appeared to be the same, I think the 01-04 have screw type fittings on both ends.
See in video at 1:04:37 you referred too. He showed the old ps rack.
2006 XC70 2.5T 190k
2006 V70 2.5T 152k
2011 C30 T5 M66 66k
Has thanked: 316 times
Been thanked: 981 times
Trinidad & Tobago
Post by abscate » Mon May 27, 2019 4:03 am
Pull them off and measure Them. Im sure you can source replacements.
Link To Volvo Glossary
