IPD sale Volvo Parts
Did you know? 🤔
2008 XC90 v8 - rattle noise at idle - serpentine tensioner? water pump? Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
mlotek511
Year and Model: 2008 V8 XC90 R
Has thanked: 2 times
Been thanked: 0
United States of America
mlotek511
Post by mlotek511 » Mon Apr 08, 2019 6:56 pm
Most noticeable at idle - it can best be heard at about 17 seconds into the video, sorry for the poor video:
Anyone have a similar noise? I tried looking on the forums/youtube but none were close to the sound I have. I was thinking starting cheap with replacing serp belt tensioners and pulleys? Or could it be possibly the water pump / power steering pump?
Thanks
Tom
Masscomguru
Year and Model: 2008 XC90
Has thanked: 0
Been thanked: 4 times
Masscomguru
Re: 2008 XC90 v8 - rattle noise at idle - serpentine tensioner? water pump?  Topic is solved
Post by Masscomguru » Mon Apr 08, 2019 7:22 pm
Have you had the idler pulleys replaced? If not, I would not run that engine until you do. When those go it’s a bad day.
These users thanked the author Masscomguru for the post:
mlotek511
mlotek511
Been thanked: 0
mlotek511
Post by mlotek511 » Mon Apr 08, 2019 7:39 pm
I have not - not sure if the previous owner did (assuming not). I was going to order:
Volvo Drive Belt Idler Pulley - 31216198 - Qty. 2
Volvo Automatic Belt Tensioner Assembly - 31216199 - Qty. 1 (Comes with Tension Holder In-Place)
Volvo Serpentine Belt - 8653617 - Qty. 1
So this is probably it?
Thanks,
Tom
mlotek511
Been thanked: 0
mlotek511
Post by mlotek511 » Mon Apr 08, 2019 8:09 pm
Ordered, will change out and report back.
jimmy57
Has thanked: 1 time
Been thanked: 144 times
jimmy57
Post by jimmy57 » Mon Apr 08, 2019 8:48 pm
The tensioner is damped. Even though it has the lock on it you will have to move it to get the lock off. The dampening is pretty strong so you put a 6 point socket on the hex nub and push on it and wait for it to s l o w l y move. A lot of these tensioners get that 19mm hex nub broken off due to expecting it to move immediately when you push on the breaker bar with socket.
These users thanked the author jimmy57 for the post:
mlotek511
mlotek511
Been thanked: 0
mlotek511
Post by mlotek511 » Sat Apr 13, 2019 6:34 pm
Replaced both pulleys and tensioner - sound is gone. Once I removed the pulleys and spun them in my hand it was obvious they were bad. FYI I am at 110k miles.
Thanks
Tom
