My ignition switch is locking up and VOLVO dealership wants $325 just for the part ......
Do i have to have them do it ?? Or can any shop do this???
Can i spray graphite in there?
Thank you
Michelle
My ignition switch/or key is needing replaced
natural4reelz
- Year and Model: 02 VOLVO S60 TURBO 5
- Has thanked: 3 times
Graphite or silicone spray
Your key has to be programmed to the Car by a shop twith access to VIDA
MacNoob
- Year and Model: 2007 XC70
- Has thanked: 2 times
I ordered a new ignition switch based on VIN ('07 XC70)... it came pre set for my existing keys and didn't need any encoding.
Part price sounds about right though!
Common to have it lock up when a little piece inside the lock mechanism breaks....
precopster
- Year and Model: Lots
- Been thanked: 128 times
That's a great idea MacNoob. The ignition lock is not "programmed" though, it just has the tumblers arranged to suit your key.
MacNoob
Here's a really good thread on stuck ignition switch - there are lots! Fortunately mine stuck at the grocery store just down the street from my house, I was able to free it up to get the car home.
viewtopic.php?f=1&t=22911&start=10
Most likely it is the switch that goes bad, not the key.
- Been thanked: 504 times
It is likely a FREE fix by removing the bottom plate.
I wrote it in detail below...
DIY: 1998 S70 GLT Ignition Tumbler FREE Fix!
viewtopic.php?f=1&t=67531
jking4020
- Year and Model: 1997 850, 2001 v70xc
- Been thanked: 3 times
Yes! Remove bottom cover under steering wheel. There is like a brass looking deal under ehere the key goes in. Take a good flathead driver and hammer and beat it a few times. It should loosen up the jam. Some say you need to take all the brass things out. But i just beat on mine a few times and it works great again. Sorry for the lame description on details but you will see what im getting at when you take the bottom cover off. Good luck.
- 2075 Views
Last post by Hendo22
- 2761 Views
- 2639 Views
Last post by volvolugnut
- 495 Views
Last post by RickHaleParker
- 1068 Views
