Did you know? 🤔
Switching out the whole rear end of my 1999 volvo v70xc. AWD TO FWD?'s
V70xc1999
Year and Model: 1999 v70 c.f. 2.4 Tu
Has thanked: 0
Been thanked: 0
United States of America
V70xc1999
Post by V70xc1999 » Tue Apr 09, 2019 8:58 pm
Ok I have a 1999 V70xc awd wagon. It is no longer awd and I am sick of everything being a cluster back there and so dam hard to work on. So I want to switch the rear end out of a fwd v70xc wagon. Can I do it??? And what years can I get the fwd rear end out off. Im shure I can..its the same frame. I would think. So need to know 1... can it be done with out a welder or anything crazy..2....what years will fit.(1999-2000)? Or more. 3....what model cars will work?(assuming only the wagons?) 4....would the back end off a xc model work?( I use for carpentry so a higher back end is sometging I would not mind.)Thanks ahead of time to any answers and replies!!!!!!!!
Has thanked: 316 times
Been thanked: 980 times
Trinidad & Tobago
Re: Switching out the whole rear end of my 1999 volvo v70xc. AWD TO FWD?'s
Post by abscate » Wed Apr 10, 2019 1:02 am
Just look for a decent FWD and pull off the commerce....dealing with two rusty back ends and then a custom fit....that gluttony for punishment
Link To Volvo Glossary
V70xc1999
Has thanked: 0
Been thanked: 0
V70xc1999
Post by V70xc1999 » Wed Apr 10, 2019 5:15 am
Actually mine is rust free(lucky me)....and it wouldnt be a custom fit if it is on the same frame I would think. Any answers to my questions? Or just sending demotivation?
Trinidad & Tobago
Post by abscate » Wed Apr 10, 2019 9:37 am
Look on the volvo parts webstore site to get the part numbers for the rear axle parts - one of the gurus will have to respond about if the frames for the XC and V70 series are the same. I don't think I have ever seen that discussed here or other Fora.
xHeart
Year and Model: 13XC90/01V70X/97N854
Has thanked: 20 times
Been thanked: 39 times
xHeart
Post by xHeart » Wed Apr 10, 2019 12:29 pm
I'm very familiar with the rear suspension and axle set up in 1997 850 FWD & 2001 V70XC AWD. AWD & FWD rear suspensions are two very different constructs.
Unless someone says otherwise, how to mount a FWD's rear SUPPORT ARM to AWD mounting point, there is none.
Golden Retriever | 2014D VIDA DiCE | 2013A XC90 +144mi/231km | 2001 V70XC 1st Owner +196mi/ +315km | 1997 Volvo 850 NA 1st Owner +180mi/ +289km
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
V70xc1999
Has thanked: 0
Been thanked: 0
V70xc1999
Post by V70xc1999 » Wed Apr 10, 2019 5:34 pm
So it is not duable at above basic mechanical skills and with out makeing some sort of custom mounting bracket? Can I remove the rear diff and axles? I have no use for them and there just in the way. Trying to loose waight and gain space as well. I dont see how it would hurt any thing...but I may be wrong. I am very surprised that the frames are different!!!!! And the mounting points wouldn't work....I would think they would have used the same frame and just made different rear ends?!?!?!?! I called and asked the dealer ship and what they said is all of the parts for the rear end..control arm etc....where the same parts for the FWD and RWD but the guy didnt know if they could swop out...
ecbsykes
Year and Model: 2000 V70XC
Has thanked: 29 times
Been thanked: 32 times
ecbsykes
Post by ecbsykes » Wed Apr 10, 2019 5:53 pm
I'm fairly certain I've seen this discussed before, as I have a 2000 XC that is FWD (shaft and angle gear removed). The general consensus that I remember seeing is that it's a giant pain in the rear (pun?) and not worth the time and effort. I've thought about removing the axles, but you still need the speed sensor that is a part of the outer axle. Personally, I'm just not gonna mess with it.
2000 V70XC - 295,000 miles
V70xc1999
Has thanked: 0
Been thanked: 0
V70xc1999
Post by V70xc1999 » Wed Apr 10, 2019 5:58 pm
Dam owell..... So not gonna do that if it start messing with sensors on these things......
V70xc1999
Has thanked: 0
Been thanked: 0
V70xc1999
Post by V70xc1999 » Wed Apr 10, 2019 5:59 pm
Realy was hopeing to switch out the back end
j-dawg
Year and Model: 1999 V70 T5
Has thanked: 1 time
Been thanked: 19 times
j-dawg
Post by j-dawg » Wed Apr 10, 2019 9:52 pm
Why not just take everything and change 100% of everything that wears? New hoses, new fuel pump, new squishy bits for the suspension, etc. Probably cheaper, definitely easier, you'll have all new parts in there, and you won't have to think about it for the next 150k miles. You'll take it out of your sphere of worry, even if it is still a mess back there.
1999 V70 T5 5-SPD | ~270k mi | burns more oil than gasoline
