2008 S60 2.5T 188K
Has anyone else had issues with their low beam headlight sockets? A couple times a year (maybe coincident with the changing weather?) my low beam headlights stop working. The bulbs are fine. If I unplug the bulb and insert some tin foil down into the socket, then put the bulb back in, they work for the next several months. Until I have to do it again.
Anyone else run into something like this?
intermittent low beam headlight issues
hu5ker555
- Year and Model: 2008 S60, 2015 S60
- Has thanked: 46 times
- Been thanked: 18 times
Bought the ceramic versions on amazon. There are only two wires in the ceramics (one on either side/terminal) but there are three on my OEMs (one on one terminal, two on the other terminal). Assuming I can just wire the two up to one side/terminal as in the OEM. Will put them in and report back.
- 1584 Views
Last post by mrbrian200
- 702 Views
Last post by osteovolvo15
- 3546 Views
Last post by 93SCMax
- 731 Views
Last post by sandyegg
- 1094 Views
Last post by Dirk1966
