Hello all, I recently purchased IPDs subframe inserts, but upon inspection of the bushings, with front bushings look as if the rubber that meets the washer are completely cracked and crumbling... Should I still install the inserts and see how it goes, or does it look like I need to replace the bushings? I really really don't want to replace them, but if it would make a huge handling difference I might consider it. I am about to do the entire front end including control arms, struts, shocks, tie rod end links and sway bar end links..
Thanks
Subframe bushing FUN!
shawneesnaketail
- Year and Model: 1995 850T Wagon
- Has thanked: 1 time
- Been thanked: 3 times
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
If those bushings are original, just have them done. It makes a big difference (at least it did for me) and I feel like they're often overlooked as a part of front-end maintenance. Get some new OEM ones AND use the IPD inserts to have a really rock solid feel.
I got some upgraded ones a while back, made from delrin plastic that are bombproof. Really tightens up the subframe.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- 2052 Views
Last post by Krons
- 824 Views
Last post by theWIFES_S70
- 22 Replies
- 5355 Views
Last post by pkc303
- 1659 Views
Last post by 2forty
- 2361 Views
Last post by June
