IPD sale Volvo Parts
Did you know? 🤔
13t boost questions
Gmstewart22
Year and Model: 2000 v70 GLT, 850-T5
Has thanked: 11 times
Been thanked: 0
United States of America
Gmstewart22
Re: 13t boost questions
Post by Gmstewart22 » Sat Apr 13, 2019 6:47 pm
In that case cant I just adjust my wastegate linkage to hold more boost?
2000 v70 GLT
1997 v70 AWD lpt
1997 v70 AWD lpt "rally rig"
1995 850 T5
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 286 times
Been thanked: 113 times
matthew1
Post by matthew1 » Sat Apr 13, 2019 7:05 pm
tardcart wrote:
Sat Apr 13, 2019 6:31 pm
not sure when boost pressure became part of the ECU input. 2000 im guessing, could be 99. Im only guessing, but people use the 99 and 98 ECU in 850's so must not have boost pressure input.
1998. 1997 is the last year for using a manual boost controller without an ECU tune.
Help keep MVS on the web -> buy from sponsors.
Also -> Amazon link
Like the high quality content? Thank a moderator.
Help MVS and be an MVS Contributor.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
Gmstewart22
Been thanked: 0
Gmstewart22
Post by Gmstewart22 » Sat Apr 13, 2019 7:09 pm
In that case I probably cant just tighten the wastegate linkage my cars was built in 97 but the vin code says is a model year 1998
2000 v70 GLT
1997 v70 AWD lpt
1995 850 T5
Gmstewart22
Been thanked: 0
Gmstewart22
Post by Gmstewart22 » Sat Apr 13, 2019 7:16 pm
Literally purchased both cars from different sellers on craigslist in the same week. One has an excellent body and transmission the other has good motor and trans but beat up body.. between the 2 I am starting my new build
2000 v70 GLT
1997 v70 AWD lpt
1995 850 T5
Gmstewart22
Been thanked: 0
Gmstewart22
Post by Gmstewart22 » Sat Apr 13, 2019 7:20 pm
My wife's car is on the far end.. same color, motor, everything except hers is MY 2000 and its front wd
2000 v70 GLT
1997 v70 AWD lpt
1995 850 T5
Gmstewart22
Been thanked: 0
Gmstewart22
Post by Gmstewart22 » Sat Apr 13, 2019 7:27 pm
Paid $450 for the one with the good motor and trans got the one with penguins sticker free from my neighbor..
Seized motor!
2000 v70 GLT
1997 v70 AWD lpt
1995 850 T5
matthew1
Site Admin
matthew1
Post by matthew1 » Sat Apr 13, 2019 9:31 pm
Cool! Good looking V70. You can adjust the wastegate for different behavior. What it does is change the RPM range when boost is available, not the amount of boost. It's a misconception that it'll increase or decrease boost pressure itself.
Volvo Wastegate Adjustment, A Closer Look - theory
Wastegate Rod Adjustment Results
These users thanked the author matthew1 for the post:
Gmstewart22
Also -> Amazon link
Gmstewart22
Been thanked: 0
Gmstewart22
Post by Gmstewart22 » Sat Apr 13, 2019 10:21 pm
Confused.. the attached article says that adjusting the wastegate will increase or decrease the amount of available boost which is what I thought it would do. The wastegate keeps the turbo from overboosting via spring/mechanical pressure against waste gate door??
2000 v70 GLT
1997 v70 AWD lpt
1995 850 T5
matthew1
Site Admin
matthew1
Post by matthew1 » Sat Apr 13, 2019 10:36 pm
If it was that easy, the ECU tuning companies would be out of business.
Also -> Amazon link
Gmstewart22
Been thanked: 0
Gmstewart22
Post by Gmstewart22 » Sat Apr 13, 2019 11:06 pm
Perhaps this is just my ignorance, but when I turn up my wastegate pressure I get an overboost code and my computer compensates by cutting fuel my tuner guy says that's what he tunes for.. he adjusts the computer to accept a higher value.. man now I'm really confused! Again pardon my ignorance I've only been into volvos for a few years and just recently started nodding them
2000 v70 GLT
1997 v70 AWD lpt
1995 850 T5
