IPD sale Volvo Parts
Did you know? 🤔
1999 V70T5M56 turbo oil line RR 9458504
Has thanked: 160 times
Been thanked: 477 times
Trinidad & Tobago
Post by abscate » Sat Apr 13, 2019 12:54 pm
Prompted by leaks pictured here
https://www.matthewsvolvosite.com/forum ... =1&t=81390
Replaced the turbo oil line, gasket. Clamp. And o-ring on the T5
Chassis break on the oil line, be careful ordering.
These parts hide under lubrication system , not turbocharger category in Volvo parts apps
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
Trinidad & Tobago
Re: 1999 V70T5M56 turbo oil line RR 9458504
Post by abscate » Sat Apr 13, 2019 1:44 pm
Tools and procedure
5 mm hex head M4 bolt hold flange of pipe to turbo
O-ring end into the crankcase is a hand press fit.
m6 ( 10mm socket) to release flange screw and nut on clamp which holds oil line and coolant line together
Vice grip to help release oil line
Turbo flange bolts released easily
Clamp bolts were very tough
To reinstall, put one bolt through gasket, raise pipe and tool together, hand thread onebolt. Use tang on gasket to set gasket into right place, insert other bolt
Torque on M4 ..I used 6 Nm as I couldn’t find a spec, so used a nominal M4 spec.
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
Trinidad & Tobago
Picture Gallery
Parts and tools.
Look at all that material wasted on the gasket - why that big tang?
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
wizechatmgr
Has thanked: 16 times
Been thanked: 43 times
United States of America
wizechatmgr
Post by wizechatmgr » Sun Apr 14, 2019 10:47 pm
Let me know if this cures your intermittent leak on the rear of the block please =)
1999 V70 XC AWD - ~172k miles
Trinidad & Tobago
Post by abscate » Mon Apr 15, 2019 2:31 am
Hope so!
One thing about the diagram above. There is a deceptive line between the oil supply line ( double banjo bolt fittings) and the return line (simple flange and flat gasket ) that implies the banjo somehow mates to the flange..it does not These two connections are independent
Redlined it for clarity
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 0
Been thanked: 6 times
tardcart
Post by tardcart » Mon Apr 15, 2019 5:10 am
Do they let you drive on the beach there? extreme corrosion. Nice write up on an often out of sight out of mind but important maintenance. now the water line.
Goupil
Year and Model: 98' V70 2.5T
Has thanked: 1 time
Been thanked: 0
France
Goupil
Post by Goupil » Mon Apr 15, 2019 6:59 am
I replaced the gasket a few weeks ago on mine, easy job once the car is on ramps and it fixed one of my oil leaks
I'd recommend fixing it asap when it leaks, p.o drove mine with the leak for a year and since it drops on the driveshaft it covers the whole engine bay in oil :roll:
1998 Volvo V70 2.5T manual Summum 193hp
Trinidad & Tobago
Post by abscate » Wed Apr 17, 2019 10:48 am
Well, power washed the underneath and have a hot run on Tuesday next week, so we will know if that has helped the wet engine back (right side) problem shortly....
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
