Fuel pressure regulator question....99 volvo v70xc
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 457 times
Been thanked: 1362 times
Re: Fuel pressure regulator question....99 volvo v70xc
I think the last pic is the rollover valve, not an Intake air control valve. That’s seals up the Evap system in case you roll the car over like June does every once In a while. If the hoses on it are fat, like 1 cm thick, that’s Evap. A leak there, or a split can make a hissing noise , too.
Non turbo cars in 99 have an iac. Turbo cars in 99 do not, it’s built into the electronic throttle body system ( ETB, ETM, or ETS are all used to describe that)
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
V70xc1999
Year and Model: 1999 v70 c.f. 2.4 Tu
Post by V70xc1999 »
Thanks.....its not comming from the hose.....it was comming from where the 2 parts join..there is only one vacume hose and 3 fuel lines that conect to... all are good.so i took apart resealed and gonna put it back in today....I will see.....there should be no air comming from or being sucked in correct...
Jbreww
Year and Model: 2000 v70 xc
Post by Jbreww »
V70xc1999 wrote: Sat Apr 13, 2019 9:06 pm 1555211171624226702049233992032.jpg pic of it out of car
Have you found the name of this plastic part. I broke mine and need to replace it. Can't find a part name or number anywhere.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 42 times
Post by FLXC90 »
https://usparts.volvocars.com/a/Volvo_2 ... 28023.html, here's you r rollover valve.
Is there any part number on the plastic adapter block? There is an o-ring on the FPR, is thee a groove for one on the mounting location for the plastic adapter?
Current Volvos:
