I just finished the PCV breather replacement on my car and in the process replaced the fuel injector filters and spark plugs (BoschOEM). I went to turn the car over and it was not starting. I could smell gas (quite a bit actually) but still no start. I decided to go back to the plugs I had in (NGK iridium) previously as they were still in pretty good shape. As I was pulling the new plugs, all of them had a small black coating of gas, except for cylinder 4, that spark plug was clean as a whistle. I put the NGK plugs in and the car fired up reluctantly and then began to run a little better. Now I think I am having a misfire because the idle is extremely rough. I removed the injector rail and the injector looks ok. Any other ideas?
I did an engine wash during my PCV change so I was only going to idle the car for about 10 minutes and then change the oil to get out any water that may have gotten in. (During the first 2-3 minutes I had smoke out of the exhaust which I attribute to the water in the engine, that has now stopped. Any ideas on what else could be causing no gas to get in to spark?
No fuel to spark
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
It sounds like you’re getting fuel flow (maybe too much?) and not not enough spark. Are the coils bolted down snuggly? I believe they need to be in order to properly ground.
Is the fuel pressure sensor plugged in?
EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 57 times
- Been thanked: 39 times
Any check engine light, any codes?
Where could water have entered the engine (what was open when washing)?
Was the engine damp when starting - perhaps shorting the spark from the wires or coils?
Did you connect the wires to the right plugs? And avoid crimping the wires by keeping them close to the coils and away from the engine cover. You should not feel any resistance as you place the engine cover.
- RickHaleParker
- Been thanked: 980 times
Did you get the intake manifold back on right? Did you replace the intake gasket?
That could explain the water ingress and the rough idle.
Active
Past
Past
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
Sounds like the engine was gas flooded at first. Swapping the plugs might of relived the gas so it could start.
While replacing the fuel injector filters what else was serviced? When I re-installed the fuel rail with 2 broken pintle caps the idle was rough. Throwing on new caps solved the rough idle.
Water potentially would have gotten in the intake ports when I washed it, but I sprayed it out with an air nozzle to help remove what I could. Intake manifold gasket is brand new from the PCV kit. It seems like any moisture has burned off. I did an oil change last night to get any water in the oil out. I think I have it eliminated down to a bad coil or injector. I just put a fresh set of Bosch plugs in and the car is running well now except for a slight dip down in idling. If I hold the accelerator down it runs ok. I am going to pick up a new coil pack tomorrow and see. I am not getting any codes from my OBD scanner.
- 3132 Views
Last post by Roger_850T
- 3392 Views
Last post by ndphotonl
- 1973 Views
- 1544 Views
Last post by FLXC90
- 26 Replies
- 4419 Views
Last post by momentumbob
