MVS-Amazon link helps MVS!
850 T5-R resleeve
Ram
Year and Model: Volvo 850 T-5R '95
850 T5-R resleeve
Post by Ram »
Hello MVS,
This might be a silly question, but I haven't been able to find a definitive answer.
I have a 850 T5-R, which engine needs a rebuild, do to cylinder wear.
Instead of finding a new block, I've opted for keeping the original block. This means a machineshop will have to work on it, but on the phone, they weren't sure, if they could resleeve it - they don't know if the walls are too thin.
I had the cylinder head off, due to burned exhaust valve, and I could feel an edge down the cylinder.
Should it be a problem to resleeve the cylinders?
PS. the engine runs, and has plenty of power, but uses too much oil.
Ras
Has thanked: 443 times
Been thanked: 1338 times
Re: 850 T5-R resleeve
You will have To measure the ridge and compare it the Volvo,specification of how much I see allowable To be removed for machining. Are you planning on this machining approach or putting new sleeves in?
A quuick look in my alldara shows Volvo support two oversizes of cylinders and pistons, 0.2 mm and 0.4 mm
If the ridge is under that depth, you could machine your sleeves, then install the oversized piston and ring set no problem
Link To Volvo Glossary
ZionXIX
Has thanked: 9 times
Been thanked: 47 times
Post by ZionXIX »
You could always obliterate the cylinders and install darton sleeves.
ZionXIX wrote: Tue Apr 16, 2019 6:06 am You could always obliterate the cylinders and install darton sleeves.
That is way too cool to watch on a work day. I think I would have one finger left after using that machine.
Ram
Post by Ram »
abscate wrote: Tue Apr 16, 2019 1:19 am You will have To measure the ridge and compare it the Volvo,specification of how much I see allowable To be removed for machining. Are you planning on this machining approach or putting new sleeves in?
I'm not sure if it's past the 0.4mm size. But I want to bore out the cylinder and put new sleeves in, so it keeps the original bore.
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 44 times
Post by callahanoffroad »
Yeah I really need this. And I'm trying to figure out how to explain to my wife that it's essential that I have this done to the block...
RickHaleParker
Has thanked: 3 times
Been thanked: 647 times
Post by RickHaleParker »
callahanoffroad wrote: Tue Apr 16, 2019 6:20 pm Yeah I really need this. And I'm trying to figure out how to explain to my wife that it's essential that I have this done to the block...
Tell her the truth, It will make the block stronger and you won't need to do it again for a long long time.
2004 S60R, B8444S TF80 AWD.
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 79 times
Been thanked: 14 times
Post by GlennG2759 »
Very, very cool video !!
Ram
Post by Ram »
Yeah, I'd like that, but that would blow my budget completely.
Shouldn't it be posible to bore out the cylinders and install new dry sleeves?
