IPD sale Volvo Parts
Did you know? 🤔
850 T5-R resleeve
Ram
Year and Model: Volvo 850 T-5R '95
Has thanked: 0
Been thanked: 0
Denmark
Ram
850 T5-R resleeve
Post by Ram » Mon Apr 15, 2019 1:47 pm
Hello MVS,
This might be a silly question, but I haven't been able to find a definitive answer.
I have a 850 T5-R, which engine needs a rebuild, do to cylinder wear.
Instead of finding a new block, I've opted for keeping the original block. This means a machineshop will have to work on it, but on the phone, they weren't sure, if they could resleeve it - they don't know if the walls are too thin.
I had the cylinder head off, due to burned exhaust valve, and I could feel an edge down the cylinder.
Should it be a problem to resleeve the cylinders?
PS. the engine runs, and has plenty of power, but uses too much oil.
Ras
Has thanked: 149 times
Been thanked: 474 times
Trinidad & Tobago
Re: 850 T5-R resleeve
Post by abscate » Tue Apr 16, 2019 1:19 am
You will have To measure the ridge and compare it the Volvo,specification of how much I see allowable To be removed for machining. Are you planning on this machining approach or putting new sleeves in?
A quuick look in my alldara shows Volvo support two oversizes of cylinders and pistons, 0.2 mm and 0.4 mm
If the ridge is under that depth, you could machine your sleeves, then install the oversized piston and ring set no problem
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
ZionXIX
Has thanked: 3 times
Been thanked: 21 times
United States of America
ZionXIX
Post by ZionXIX » Tue Apr 16, 2019 6:06 am
You could always obliterate the cylinders and install darton sleeves.
These users thanked the author ZionXIX for the post (total 2):
KlauscGlennG2759
Trinidad & Tobago
Post by abscate » Tue Apr 16, 2019 6:26 am
That is way too cool to watch on a work day. I think I would have one finger left after using that machine.
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
Ram
Has thanked: 0
Been thanked: 0
Denmark
Ram
Post by Ram » Tue Apr 16, 2019 11:14 am
I'm not sure if it's past the 0.4mm size. But I want to bore out the cylinder and put new sleeves in, so it keeps the original bore.
callahanoffroad
Year and Model: 1995 850
Has thanked: 13 times
Been thanked: 9 times
callahanoffroad
Post by callahanoffroad » Tue Apr 16, 2019 6:20 pm
Yeah I really need this. And I'm trying to figure out how to explain to my wife that it's essential that I have this done to the block...
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. Herman. https://www.matthewsvolvosite.com/forum ... =1&t=84393
RickHaleParker
Has thanked: 2 times
Been thanked: 247 times
RickHaleParker
Post by RickHaleParker » Tue Apr 16, 2019 6:34 pm
Tell her the truth, It will make the block stronger and you won't need to do it again for a long long time.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
GlennG2759
Year and Model: 1994 850 Base
GlennG2759
Post by GlennG2759 » Tue Apr 16, 2019 6:54 pm
Very, very cool video !!
Ram
Has thanked: 0
Been thanked: 0
Denmark
Ram
Post by Ram » Wed Apr 17, 2019 12:29 am
Yeah, I'd like that, but that would blow my budget completely.
Shouldn't it be posible to bore out the cylinders and install new dry sleeves?
