clicking noise on 98 s70
Cvovo7
- Year and Model: 1996 Volvo 850 GLT
- Has thanked: 6 times
I am starting to hear a clicking noise when throttle is pushed as if there is something rattling against exhaust. Unfortunately, i have searched while someone has pressed on the gas and cannot pin point where sound is coming from. I do know cv axles need done. But if I'm correct, they only do the clicking noise only while making sharp turns. correct???? This sound usually occurs when car is accelerating. the harder you push on the gas, the louder the clicking or rattling noise is. Engine is maintained with proper oil and has enough in it. Injectors??? Any help is good with this situation.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Is it more of a clicking, or a rattling? Does the noise occur when reving the engine in neutral while stationary? Could be lifter tick, which is a sign the oil pickup seals need replacing.
Knows enough to be dangerous
Cvovo7
in neutral not as loud but still noticeable. I definitely appreciate your input on the subject. Is that expensive to fix and do you recommend changing all at once. Any other maintenance i should do while top off of motor?
- WhatAmIDoing
Oil pickup seals is a bottom end job. Not overly difficult for two people to do in the driveway on a nice Saturday. Regardless, you have to isolate the noise. Use a length of rubber hose, or an inverted long funnel, or ear on long screwdriver while someone revs the engine to isolate the noise. Videos usually don't help much, but you can try posting one.
- 744 Views
Last post by Cees Klumper
- 1064 Views
Last post by Clockboy
- 1795 Views
Last post by dcarlson12
- 2734 Views
Last post by velorider
- 849 Views
