Did you know? 🤔
P80 Positive Temp Coefficient Nipple "PTC VALVE" To drill, or not to drill
Has thanked: 318 times
Been thanked: 988 times
Trinidad & Tobago
Post by abscate » Tue Apr 16, 2019 6:58 am
I sit wiser in the end to suffer the slings and arrows of outrageous Crankcase pressure on the PTC Nipple?
This thread is for discussion on drilling, cleaning, and both on high mileage Volvo P80 engines
Volvo says clean every 60k
Excellent teardown thread here by Lee
https://www.matthewsvolvosite.com/forum ... =1&t=68898
Link To Volvo Glossary
Trinidad & Tobago
Re: P80 Positive Temp Coefficient Nipple "PTC VALVE" To drill, or not to drill
One jerks opinion
The PTC Nipple
The PTC (Positive Temperature Coefficient) Nipple is just a hole, or Orfice nipple , to use the Volvo term. Its often mistakenly called a valve as it has an electrical connection, but that is just a heating element to keep the sludge from condensing and blocking it. It is a valve in the sense that it regulates vacuum to the Positive Crankcase Ventilation system, but it does not open and close like most think of a valve.
It is often drilled out, when in fact it is a required cleaning maintenance item every 60k miles on a new car, and (my recommendation) 30k on an old Volvo.
The reaction to "Hey the PTC is clogged, lets drill it out" should be "Why didn't I clean this per schedule?"
No judging here.
:D
Rattnalle
Has thanked: 20 times
Been thanked: 123 times
Sweden
Rattnalle
Post by Rattnalle » Tue Apr 16, 2019 7:06 am
Volvo put it there for a reason. Don't mess with it other than making sure it works by cleaning it.
My two cents.
PS that goes for things like cats and other stuff as well.
Trinidad & Tobago
Post by abscate » Tue Apr 16, 2019 7:13 am
I could not find the PTC Nipple as a separate part - it does come with the Air Hose (Snorkel)
9186200 9445351
Danonly55
Year and Model: 1996 850 sedan
Has thanked: 19 times
Been thanked: 3 times
United States of America
Danonly55
Post by Danonly55 » Tue Apr 16, 2019 7:20 am
Can this part be accessed without removing the intake manifold?
1996 Volvo 850 sedan base
1980 Mercedes benz 300sd " Shotzie"
1997 Ford f350 7.3
Life is tough, but it's tougher when your stupid'
" John Wayne
ZionXIX
Has thanked: 9 times
Been thanked: 41 times
ZionXIX
Post by ZionXIX » Tue Apr 16, 2019 7:59 am
Mine didn't even need to be drilled. It just popped out with a little prying.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 44 times
Been thanked: 154 times
bmdubya1198
Post by bmdubya1198 » Tue Apr 16, 2019 8:20 am
Yes, it sits at the bottom of the intake elbow, just before the turbo inlet.
The concept of drilling it out is to help vent crankcase gasses back into the intake a little easier. Usually the PTC itself is able to be removed with some prying, no drilling required for removal.
2000 V70R Venetian Red/Charcoal M56 Swapped 195k
2003 S60 2.4T Silver/Black 112k
2007 XC90 V8 AWD Sport Titanium Grey/Black 166k
1991 944 Turbo Dark Green/Beige 173k
1992 245 Base White/Beige 249k
2006 BMW 330i
1999 BMW 528i
2000 S70 GLT Mystic Silver/Taupe 253k
1993 944 Base Beige/Beige 221k
1998 V70 GLT Black/Beige 199k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
Has thanked: 95 times
Been thanked: 284 times
Post by erikv11 » Tue Apr 16, 2019 9:00 am
I first posted these in ZionXIX's thread viewtopic.php?f=1&t=84698. It's been 18 months now, with no ill effects on my 95 R.
The PTC is not available separately as a replacement part, good news is you will almost never need a new one, there's nothing to break or wear out. Great junkyard part in that sense.
The grommet for the base of the PTC is available separately from Volvo as part number 3507985, about 4 bucks. Very worthwhile to replace that!
These users thanked the author erikv11 for the post:
Chuck W
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 286k
'06 S60 R, 167k
'99 Camry V6 :shock: 125k
Post by erikv11 » Tue Apr 16, 2019 9:08 am
Yes, it is not located near the intake manifold it is down low near the brake booster at the firewall. And non-turbo cars like yours do not have a PTC. You may be thinking of the flame trap orifice specific to NA cars, which can be accessed by removing the air intake from the front grill and/or the air filter box for full access,.
'96 855 NA, 145k
'06 S60 R, 167k
Chuck W
Year and Model: 97 854 T5
Chuck W
Post by Chuck W » Tue Apr 16, 2019 9:10 am
Thanks for that PN. When I did the PCV refresh on both cars, that grommet was pretty soft and I wondered if a replacement was available.
