Hello all,
I want to replace my front door speakers, but wasn't sure if I also needed to replace the tweeters in the dash at the same time, or can I just simply swap out the speaker? Also, Crutchfield shows that 5.25", 6.5", and 6.75" will all fit. Is that accurate? If so, I have a pair of new Kenwood 6.5" speaker's I found in my garage from a different project that I can likely reuse, though they are 4ohm units...
Replacing front door speakers
- clarkerussell
- Has thanked: 20 times
- Been thanked: 4 times
- clarkerussell
Never mind, I found the lovely write up about the replacement process here.
viewtopic.php?t=57976
That being said, I don't see anything about the use of 4 Ohm vs 8 Ohm speakers.
- Has thanked: 292 times
- Been thanked: 765 times
That very writeup you linked says it used all 4 ohm speakers, and Lee opines that it shouldn't matter.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- clarkerussell
You are correct Erik, I didn't read into the comments section, but it is definitely in there...
- 24 Replies
- 8628 Views
Last post by LOB
- 4435 Views
Last post by bill d cat
