Has anyone tried swapping the 2007-2009 S60 steering knuckle and control arm into an earlier chassis?
I received the wrong part from Erie VoVo, and thought that it would be nice to go to a larger ball joint and the nicer castings used in the later model cars. I am working on my 2002 V70 XC, which has a bad swede lift and XC90 half shaft/CV axles. The smallish balljoint is enough of an issue that Volvo made an engineering/manufacturing change for just 3 short years of S60 production, and just one half year of the V70.
Control Arm/Steering Knuckle swap S60/V70
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I am under the impression the XC70 uses a different control arm than the S60, even when comparing a 2002 S60 with a 2002 XC70. The ca on the S60 is thinner and has a different shape than on the XC70
For ball joints, use Lemforder, they provide the OEM for Volvo
- MDK
- Year and Model: 2004 S60R
- Been thanked: 42 times
Hey there Oragex...MDK here. I bought 2 control arms for my 2002 V70 2.4 non turbo only to install them on my 2004 S60 R AWD... If that helps. I think the difference is steel ones versus aluminum. Thanks for all your previous advise. Ciao....MDK rolling on
- oragex
Good to know the CA on awd are same as fwd. That's one beautiful R
- 787 Views
Last post by oragex
- 814 Views
Last post by Ozark Lee
- 1542 Views
Last post by harryhendo
- 2277 Views
Last post by RussB
- 14 Replies
- 6620 Views
