96 850 turbo TCV Line diagram help
jakethesnake
Year and Model: 1996 850 Turbo Wagon
Has thanked: 2 times
Post by jakethesnake »
hey forum,
so looks like someone had the tcv lines hooked up wrong and I'm trying to piece together correctly.
I have the diagram in front of me and i can't figure out where the red line (part 20) plugs into.
diagram: http://www.volvohowto.com/volvo-850-tur ... es-diagram
Thanks
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Post by tardcart »
that is the compressor bypass line it goes over to the the intake manifold tree. It sends boost pressure over to open the CBV mechanically depending on the spring installed, 8 pounds of boost stock. its function is to vent boost if you suddenly see a cop during high boost but before the waste gate can dump.
Has thanked: 1609 times
Been thanked: 4064 times
tardcart wrote: 22 Apr 2019, 20:15 that is the compressor bypass line it goes over to the the intake manifold tree. It sends boost pressure over to open the CBV mechanically depending on the spring installed, 8 pounds of boost stock. its function is to vent boost if you suddenly see a cop during high boost but before the waste gate can dump.
Thanks for correcting my fubar post.
