Well I need to know a cpl things...
First off I have oil in my coolent not a whole lot but enuff to turn a darker green.
No colent in oil... as what I can see now.
I need to know what are the odds of it being a cracked head and not the gasket?
I am thinking when I have it torn apart I can check with this spray that finds cracks.
So my 2 main questions
what kit to get for the head gasket job
What brand
MAHLE....ITM....FELL PRO....BECK ARNLEY
And any recommendations on finding a crack in the engine ..
..what spray kit to buy? iv seen a few.
..is this the best way? I am tearing it down anyways and dont have presure tester. Thanks guys
Head gasket repair......1999 v7xc
Let the collective brain chew on this for a week, but in my recollection gaskets outnumber head issues by 50:1 - its a good bet it is just gasket.
Of course, once the head is off, you check it for being true and skim if required.
All that labour? OEM Volvo.
It will be about $70 if you have the right one.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Victor Reinz.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 311 times
- Been thanked: 817 times
This year has the biscuit oil cooler, or the one in the radiator?
Still I would probably try compression testing the cylinders, some more poking around before disassembly if all you know so far is that there is oil in the coolant. Compression tester is free to rent from most auto parts stores
- 18 Replies
- 5853 Views
- 485 Views
Last post by erikv11
- 1160 Views
Last post by sk55
- 774 Views
Last post by RickHaleParker
- 977 Views
Last post by turtlehead
