IPD sale Volvo Parts
Did you know? 🤔
1999 S70NA Manual Climate Control MCC 3524842 Cable attachment
Has thanked: 191 times
Been thanked: 603 times
Trinidad & Tobago
Post by abscate » Wed Apr 24, 2019 3:10 pm
My passenger temp control was not regulating, reaching around the dash, I could feel the cable had popped off the MCC gudgeon, so I went to work
Unlike an ECC controller, the MCC controller is removed by unscrewing the rear part (the part you see) from the console frame, then unclipping the FRONT part (hidden in dash)
From there, you can manipulate it enough to reattach the cables with some tricks
Unclip the cable from the frame (snap in) so that it is free
The eye on the cable goes on the gudgeon, the wire gets retained by the C clip built into the plastic gudgeon
Put the eye on the shaft, then turn the temp knob hot to use the frame to retain it.
Tools
Torx T15 for screws
SPudger to release plastics frame and clips
Put a shot of silicone spray into top of each wire to make things move smoothly
Elapsed time 25 minutes
*** Be careful with that MCC - its a $450 part and eBay is no help - hard to find in PnP.
These users thanked the author abscate for the post:
matthew1
Trinidad & Tobago
Re: 1999 S70NA Manual Climate Control MCC 3524842 Cable attachment
Post by abscate » Wed Apr 24, 2019 3:13 pm
Picture Gallery
Temperature knobs pop off, note T15 screw
Just grab and tug
Nice and easy on old plastic
Same on the pass side
Here is the driver side in correct position
Two plugs connect to REAR of MCC controller
Unclip two clips on each side of MCC controller, then push it forward
Rear side of MCC controller pulls forward, release with spudger on sides and top/bottom
Pass enter side installed correctly
Heres why passenger was always at constant Temperature!!
Working through hole, you can manipulate the controller to get wires connected correctly
I put the knob back on to go to COLD position to connect wire, then turn to hot to retain
bmdubya1198
Year and Model: '98 V70 GLT
Has thanked: 27 times
Been thanked: 78 times
United States of America
bmdubya1198
Post by bmdubya1198 » Wed Apr 24, 2019 9:27 pm
Nice writeup. Those cables are a pain to work with, and the MCC unit is a lot more complicated to remove than the ECC. I'm currently removing the MCC unit from the 850. Fortunately this one works, so I'll give someone a good deal on it if they need it!
1998 V70 GLT Black/Beige 193k
2000 V70R Venetian Red/Charcoal M56 Swapped 188k
2001 S60 2.4T Black/Black 230k
2007 XC90 V8 AWD Sport Titanium Grey/Black 155k
1998 S90- Silver/Gray 207k
1995 850 collection of parts... crushed... still have parts, PM if interested!
1988 744 Turbo M46 Beige Metallic/Beige 188k- Still kicking myself for getting rid of this one
