1995 Volvo 850 T-5R, Yellow, Sedan, 223K, $4,000 OBO, Lancaster, PA
flat467
Year and Model: 1987 240
Post by flat467 »
1995 Volvo 850 T-5R Sedan in Yellow
Year: 1995
Make: Volvo
Model: 850 T-5R
VIN(s): Body - YV1LS5817S2229312, Engine – YV1LS5814S2238470
Condition: Used, Good
Mileage: Body-300k Engine – 223k
Exterior: Cream Yellow, 6.5/10
Interior: charcoal/alcantara, 8/10
Body: 4dr, Sedan
Tranmission: 4-speed Automatic
Engine: 2.3L i5 Turbo
Asking Price: $4,000
Preferred Method Of Contact: [email protected]
Services performed prior to my owner ship at 222xxx miles
- Full engine swap from another ’95 T-5R sedan, including dash and cluster (cluster reflects engine milage)
- During swap: timing belt, water pump, aux belts, cam seals, valve cover gasket, PVC System, spark plugs, wires, and cap/rotor were all replaced.
- Brake pads and rotors all around at time of swap.
- Bilstein Shocks all around
Services performed under my owner ship from 222k to 223k miles
- Oil/oil filter change Oct/18
- Wiper blades replaced Oct/18
- MAF replaced Oct/18
- Glove box latch replaced Oct/18
- TB cover replaced Oct/18
- Air intake hose replaced Oct/18
- Air intake filter replaced Oct/18
- Front and Rear mudflaps replaced. Nov18
- Front rubber brake lines replaced with stainless steel lines Dec/18
- x70 door handles replaced with 850 Style handles, with working lock and key. Dec/18
- Tires balanced, rotated, and aligned Dec18
- Fuel pump assembly replaced Dec18
- All plastic trim color corrected May19
- Painted Front grill replaced with stock Al grill April19
- New battery April19
The not to good:
- Paint is faded on hood
- Front fender has a clip that has begun to oxidize on the exposed steel
- Passenger door paint clipped away on bottom quarter and has begun to oxidize
- Parking brake hold is weak
- plastic trims behind headlight wiper blades have many stone clips (replacements included)
- driver side wheel speed sensor is throwing an open circuit/short circuit code causing the ABS/TRACS light to remain on, suggested cleaning or replacing wheel speed sensor (25$ part)
Things that come with the car that I have yet to do myself:
- Top Engine torque mount (the current mount has not failed, but I bought a new one for the future)
- Rear Stainless Brake lines (meant to replace with the front SS, but never got around to it)
- parking brake shoes and hardware
- Trunk Struts
- colored plastic trim that goes behind the headlight wiper blades. (green in color)
- x70 color matched door handles
I have enjoyed owning this car and taking care of it for the short period of time that it has been (Oct/18 to April/19). Please feel free to DM me to ask any questions you may have, and feel free to read the thread I have created to share this car with the Swedespeed Community https://forums.swedespeed.com/showthrea ... dan-Thread
I will be showing the car at Carlisle this year, unless of course someone purchases it before May17. If someone does purchase it before Carlisle, I will work with them to transfer my non-judged show field registration to them free of charge!
Thank you for looking!
-Alex
