IPD sale Volvo Parts
Did you know? 🤔
2000 C70 2.4 T (B5244T) has spark + fuel
DeadEric
Year and Model: 1996 850 Turbo
Has thanked: 2 times
Been thanked: 9 times
United States of America
DeadEric
Re: 2000 C70 2.4 T (B5244T) has spark + fuel
Post by DeadEric » Wed May 01, 2019 7:55 am
I noticed in the video that your intake timing mark stops at the same spot both times. It goes around once freely then stops on the second go around.
I don't know what that means exactly but I think it's a clue. Points to mechanical in my mind, hopefully someone more knowable can chime in.
Has thanked: 180 times
Been thanked: 542 times
Trinidad & Tobago
Post by abscate » Wed May 01, 2019 8:03 am
Go through and systematically check that the coils are in the right place. I can see that the loom has been reworked - it might be the colour coding has been changed so you will have to sort that out somehow
That kick and backfire is indicative of spark being there but on the wrong cylinder.
You do have an ignition problem of some kind, or timing of valves.
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
Kerpre
Year and Model: 2000 c70
Has thanked: 0
New Zealand
Kerpre
Post by Kerpre » Fri May 10, 2019 5:41 pm
Thanks for your reply mate
Cam and crank sensors are good (giving signal) and no codes
Compression on each cyl is at least 155psi so I don’t think it’s washed the rings.
I’ll list off a few things I’ve checked. If you can thi k of anything g else that would be great. Also how do I check the tps? I though this vehicle has an electronic throttle body.
So,
Compression is all atleast 155psi on all cyl
Fuel at the rail is 48psi
Injectors are cycling (have removed rail and cranked over)
Timing appears to be spot on.
No codes for anything(using obd2 memo scanner)
Good strong spark
Cam and crank sensors have been pulled and bench tester and checked out.
I just can’t think of anything else it may be.
Thanks for your help
Kerry
RickHaleParker
Has thanked: 3 times
Been thanked: 299 times
RickHaleParker
Post by RickHaleParker » Fri May 10, 2019 6:12 pm
Make sure the Coil Pack Loom is connected in the correct order.
There is one striped wire that is a different color for each cylinder.
Per the Electrical Wiring Diagram (EWD).
Cylinder 1 Yellow-Black.
Cylinder 2 Orange-Black
Cylinder 3 Blue-Black
Cylinder 4 Green-Black
Cylinder 5 Yellow-Red.
Last edited by RickHaleParker on Fri May 10, 2019 6:17 pm, edited 1 time in total.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Sommerfeldt
Year and Model: 1996 850 T5
Has thanked: 42 times
Been thanked: 25 times
Norway
Sommerfeldt
Post by Sommerfeldt » Fri May 10, 2019 6:15 pm
What RHP said.
Also, can you hook that thing to VIDA and see if you get any feedback there? Only other thing I can think of would be immobilized issues, but that should set a code.
- S
'96 855 T5, R bumper and spoiler, Koni Yellows & blue H&R springs all 'round.
Kerpre
Has thanked: 0
New Zealand
Kerpre
Post by Kerpre » Fri May 10, 2019 10:21 pm
Hey guys thanks for the posts.
Ignition cables are all matching up apart from cyl 4
I have black with grey stripe.
I’ve decided I’m going to re-time her and see how we go from there
RickHaleParker
RickHaleParker
Post by RickHaleParker » Fri May 10, 2019 11:43 pm
Had a '97 S90 that flat refused to start unless the camshaft position sensor was disconnected. Turned out the PO had gotten the blocking cup on the end of the camshaft installed 180° off. Corrected that and it fired right up with the camshaft position sensor connected.
My S40 would not start after a timing belt service. Disconnected the camshaft position sensor then with some extended cranking it started.
Worth a shot to disconnect your camshaft position sensor and give it a try.
Kerpre
Has thanked: 0
New Zealand
Kerpre
Post by Kerpre » Sat May 11, 2019 12:15 am
Alrighty fellas!! After 6 months of struggle, the c70 lives! Runs a little rough but she is running ! Thank you Rick for posting the ignition wiring, my 1 &2 cylinders were around the wrong way and marked as Sony the prev owner 😓 I should of bloody checked
Thank you again guys
These users thanked the author Kerpre for the post:
Sommerfeldt
Sommerfeldt
Norway
Sommerfeldt
Post by Sommerfeldt » Sat May 11, 2019 2:00 am
Nice! All’s well that ends well! :)
- S
RickHaleParker
RickHaleParker
Post by RickHaleParker » Sat May 11, 2019 2:20 am
Let me guess ..... had trouble telling the Yellow from the Orange.
There is a reason electrical guys insist on good lighting.
