Keep getting the P0443 code which is leaving me unable to renew my tag. So far, I’ve replaced the following:
1. Purge valve (twice)
2. Fuel shutoff valve (twice)
3. Hose from the purge valve that “y’s” out to the intake manifold and engine intake hose
4. J-pipe
Any other ideas?
P0443 but I've replaced everything - 2000 S70 AWD
AustinAbney
- Year and Model: 2000 S70 awd
- misha
- Has thanked: 155 times
- Been thanked: 432 times
You are on the wrong path:
https://www.google.com/amp/s/repairpal. ... it-low.amp
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
AustinAbney
My bad. I was multitasking when I made this post. I'll adjust the content and title.
I have a code P0443, not P0043. Doh!
Now, any ideas anyone?
- RickHaleParker
- Been thanked: 978 times
You got a open, short or a power supply failure in the loom to the Purge Valve.
1. Check/clean the connector to the Purge Valve.
2. Make sure the Purge Valve is getting power.
3. Ohm out the loom for shorts and opens.
Active
Past
Past
AustinAbney
I'll get looking. Any chance the B+ cable from the battery could have anything to do with this?
I know it's late to the party. But I had the same deal changed out all the culprits only to realize it was a blown 20amp fuse. Now that's a DOH! moment!
Well, 3 miles down the road and it's back (P0443). So now I'm going to see where the short is occurring. Start with the CVVT that I changed out, reverse the wiring perhaps. That is when this all started. Fingers crossed.
Nope wasn't that!
Couldn't find any shorts. But when I swapped the wires on the CVVT , ran like crap. so they were correct. And when I swapped them back the fuse blew. So i then decided to put the original CVVT back on and low and behold runs with no fuse blown out. OK is the new Solenoid bad. Anyone know the resistance for one of these things? I get around 4 ohms. I'll haft to search around and see if I can find it. Can't return it cause I ordered it last year damn it.
Nope wasn't that!
- 2455 Views
Last post by nyc1836
- 2276 Views
Last post by RickHaleParker
- 828 Views
Last post by 93Regina
- 1407 Views
- 17 Replies
- 3452 Views
