P0442 = J Hose? 2002 V70
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 157 times
Been thanked: 6 times
Post by Mr. Detail »
I am being told that most likely my P0442 check engine code is that so called "J" hose right near the left rear wheel on my 2002 V70. Supposedly it goes to the charcoal canister. Does this sound right?
Reason: improved title
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
'J" hose is the second most common cause but not the only possible cause.
Possible source
Major leak:
Fuel tank filler cap missing, not tightened or defective seal (#1 cause)
Leakage that is 1 mm or greater in the fuel tank, fuel filler pipe, fuel tank filler cap, EVAP canister, canister purge (CP) valve, or in the hoses between these components
The fuel gauge does not function (This fault is detected by the rear electrical module).
Minor leak:
Leakage that is 0.5-1.0 mm or smaller in the fuel tank, fuel filler pipe, fuel tank filler cap, EVAP canister, canister purge (CP) valve, or in the hoses between these components
Keep in mind five 0.01 will add up to 0.5.
Active
Past
Mr. Detail
Thanks "Mr. Parker" for that response. It certainly would be an easier fix for me if I can't get under the car by that rear wheel.
I will order up a new filler cap today, sir. Thx!
RickHaleParker
Mr. Detail wrote: 29 Apr 2019, 14:07 Thanks "Mr. Parker" for that response. It certainly would be an easier fix for me if I can't get under the car by that rear wheel.
Did you pull the filler cap off, inspect it and find something wrong?
Active
Past
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
If replacing the J-hose is required you drill out the pop rivets of the LR fender plastic and get it out of the way.
Big body pop rivets require the larger size gun or one with replaceable collets.
My '02's J-hose went out at 107K and 8 years of age.
Mr. Detail
RHP, yes I opened the gas filler door and inspected the cap last evening. It looks to me that I had already replaced the whole cap a few months back. It looks brand new to me. Can the seal on the cap go that fast?
RickHaleParker
Mr. Detail wrote: 30 Apr 2019, 08:05 Can the seal on the cap go that fast?
Poor fix to start with Yes.
Wear out no.
However they have TV shows on how fast something can be destroyed ... Damage does not take long.
That why I ask if you inspected it.
Active
Past
