IPD sale Volvo Parts
XeMODeX - Experts in Volvo Electronics My Swedish Parts ad - genuine Volvo parts
Did you know? 🤔
Too much of a good thing - extra tranny fluid?
2001 - 2007 XC-70
IslandV70
Year and Model: 2005 V70 2.4
Has thanked: 2 times
United States of America
IslandV70
Post by IslandV70 » Thu May 02, 2019 11:13 am
My car sometimes shifts harder than I would like. I have 68,000 miles and the fluid was flushed and replaced by the Volvo dealer back around 35,000 miles or so.
I checked the dipstick and the fluid is above the high mark for HOT after driving around 5 miles on a warm day. It also seems red and smells like new fluid does. Just by visual checking it seems nowhere near ready for changing, but since the cold mark is below the hot mark I assume the hotter it gets the more above the full line it will be. Did the idiots back at the dealer just dump in too much? I have a vacuum sucker, should I suck some out?
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 23 times
vtl
Re: Too much of a good thing - extra tranny fluid?
Post by vtl » Thu May 02, 2019 11:50 am
Add 1 oz of Lubegard HFM and install an external oil cooler + Magnefine filter.
2005 XC70 250k
2016 XC60 40k
Has thanked: 192 times
Been thanked: 620 times
Trinidad & Tobago
Post by abscate » Thu May 02, 2019 12:20 pm
Too much is bad and will impact operation. Just crack the drain and let some out. The distance between marks is about 0.5 liter, so use that distance to gauge amount to remove, then do the standard check of oil level (hot ATF, idle,move through all gears, then back to P.
oragex
Year and Model: S60 2003
Has thanked: 81 times
Been thanked: 177 times
Canada
oragex
Post by oragex » Thu May 02, 2019 12:32 pm
My take on this, I had a fluid that was expanding too much when warmed up, and was showing way past the hot mark on the dipstick. I've run like that for over 1 year with no issues. There is too much, and then there is way too much. Just 1/2" above the hot mark - in my opinion - is no problem, but of course it's good to stay within the limits
But let's assume it was overfilled (I would really doubt it was, given it was serviced by the main dealer), the fluid would show foaming perhaps even on the dipstick - if instead the fluid shows no tiny bubbles on the dipstick I wouldn't worry. It's the foaming that can affect the transmission, because it introduces air into those passages and may reduce lubrication or have other effects.
As mentioned above, I'd also make sure to measure to use the dipstick the right way, on a perfectly level surface, with engine running, in P, etc. I did suck a little out of mine, takes very long with a small tube, try with the transmission slightly warmed up so the fluid is more 'fluid' and runs easier
Small question, when you say the Volvo dealer replaced the fluid, is this verbally mentioned by a previous owner, or there are receipts showing this ? Just in case it was only mentioned by a PO who instead did himself replace the fluid, for example
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
Marcobrick
Year and Model: 2003 V70T5
Been thanked: 0
New Zealand
Marcobrick
Post by Marcobrick » Fri May 03, 2019 1:26 am
Mine was more than a quart overfilled when I bought it and had been for a long time by the look of it. No ill effect noticeable, and after a couple of drain and fills and now at the correct level it feels exactly the same, shifts great etc. so I wouldn’t panic, but go ahead and suck a bit out. A Mityvac is great for this.
2003 V70 T5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
1996 850R sedan
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
Trinidad & Tobago
Post by abscate » Fri May 03, 2019 3:53 am
Hasn’t your excess fluid made your passenger headlight wiper fall off?
Always like your videos orangex...
IslandV70
IslandV70
Post by IslandV70 » Fri May 03, 2019 5:52 am
From the carfax:
32,340
Martens Volvo Volkswagen
Washington, DC
202-537-3000
martenscars.com
Recommended maintenance performed
7,500 mile service performed
Transmission fluid flushed
Tune-up performed
Power steering reservoir replaced
A/C refrigerant recharged
Computer reprogrammed
Power window computer/module reprogrammed
Tire condition and pressure checked
01/17/2010
The car currently has about 65,000 miles.
oragex
Canada
oragex
Post by oragex » Fri May 03, 2019 7:15 am
One of those wiper motors always get stuck in a weird looking open position making that wiper rest at an angle. I like symmetry so pulled the guy from there and actually even sold them :D also disconnected the fluid hose to the headlights Plus now it's easier to clean the snow off the parked car, a bonus
oragex
Canada
oragex
Post by oragex » Fri May 03, 2019 7:21 am
From the carfax:
32,340
Washington, DC
202-537-3000
martenscars.com
Tune-up performed
01/17/2010
Oh I remember, the well maintained car
Maybe try measuring again with the tips in the video, let us know by how much it's overfilled. Undoing the lower drain plug is now easy because it's a huge nut and may not have a wrench for it plus it may be quite tight. If you decide to suck some fluid out, use a long small transparent hose that fits inside the dipstick (there is not refill hole on this unit, don't try removing some upper bolt), with the transmission a little warm, the end of the tube must basically lay on the ground - careful not to don't touch fluid with your lips. May remove like 1qt, then put back the amount needed.
