IPD sale Volvo Parts
Did you know? 🤔
850 2.5L 20 V Rescue
manovlov
Year and Model: 850 WAGON 95 2.5-20V
Has thanked: 38 times
Been thanked: 8 times
France
manovlov
Post by manovlov » Thu May 02, 2019 1:14 pm
Hy Buddies,
I have technicals questions. I will pick up my new 850 (called Blue) on Saturday far as 1000 kms from home. Bus from home to Geneva airport, then plane to Amsterdam.
The seller can't tell me when the timing and serpentine belts have been changed the last time. Volvo Cars garage doesn't exist anymore and has been replaced by a Volvo Trucks garage. So, no solution to get the historic of Blue.
If I succeed in find the rights belts for blue, is it possible to change them without unscrew the all circuit ?
If I lose the belt tensionner with the white plastic clip, will I be able to put it back without problem ?
I need wrenches 10 - 12 , torx 25, wrench for the damper pulley (24 or 34), a tool to block the plastic panel inside the wing, do I forget something ?
And I have no tool to block cams, will it be possible also to change the belts so ?
Last one : have you guys, the picture of which way install these belts ?
Thanks to you all.
Manov
Vroum !
Has thanked: 189 times
Been thanked: 601 times
Trinidad & Tobago
Re: 850 2.5L 20 V Rescue
Post by abscate » Thu May 02, 2019 1:20 pm
Just drive it back home Manov - it will be fine. The belts last at least 50% longer than the service interval, and Amsterdam to Greboble is about 500 miles? Thats only one week driving
:D :D :D
manovlov
France
manovlov
Post by manovlov » Thu May 02, 2019 1:21 pm
The car has 141 000 kms...
Amsterdam - Grenoble : 1021 km exactly :D
Vroum !
Trinidad & Tobago
Post by abscate » Thu May 02, 2019 1:25 pm
I drove my V70 137,00 miles past the 105,000 mile timing belt interval. If the belt looks ok and there are no noises from the pulleys or water pump seepage, Drive it home and enjoy Chardonnay on the trip (I think that is your famous wine??)
Promise Blue you will fix her when you get home.
Be French and take a risk !! If you hadn't crossed the Channel in 1066 we wouldn't have any Norman castles in the UK
These users thanked the author abscate for the post:
manovlov
manovlov
France
manovlov
Post by manovlov » Thu May 02, 2019 1:31 pm
:D :D :D
That's right ...
We should have stayed longer, because, when you see how theirs castles look...
I will caress Blue's hood from your part, promised !
Manov
Vroum !
manovlov
France
manovlov
Post by manovlov » Thu May 02, 2019 1:41 pm
... a small one before the road...
I need to buy stuff for blue; I will use IPD link from the website. The engine parts search asked me for the type of fuel system. How may I know ?
- H 3.2 (BOSCH LH 3.2 ELECTRONIC FUEL INJECTION)
or
- ME4.3 ( BOSCH MOTRONIC 4.3 FUEL INJECTION)
or
- CHARDONNAY ENGINE INJECTION FUELED ?
Vroum !
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 36 times
United States of America
tardcart
Post by tardcart » Thu May 02, 2019 3:30 pm
good advice to just drive it home. You are more apt to make a mistake under pressure on the side of the road. You could take the one 12mm bolt that holds the cover off and look at the belt for a More relaxing trip. takes 3 minutes. as previously posted, if you have a water pump leak: that can seize up immediately and break the belt.
These users thanked the author tardcart for the post:
manovlov
manovlov
France
manovlov
Post by manovlov » Fri May 03, 2019 4:09 am
You're right Guys,
Everything will be fine. It's a Volvo.
Manov
Vroum !
Trinidad & Tobago
Post by abscate » Fri May 03, 2019 4:59 am
Take pictures and post! I’m usually on the coast at LaRochelle using a Volvo diesel...
RickHaleParker
Been thanked: 305 times
RickHaleParker
Post by RickHaleParker » Fri May 03, 2019 5:14 am
How may I know ?
or
or
Pull the cover of the ECU box located in the passenger side, front corner of the engine compartment. Take a picture and post it here.
These users thanked the author RickHaleParker for the post:
manovlov
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
