Anyone seen this one before? I think this is why the oil condition was so bad, I don't think the previous owner changed the oil for a while. The cams were coated with oil resin or varnish. Anyways any tips appreciated thanks
PS how do the cam lobes and lifters get oil? I see the oil port feeding the cam journals but don't see how it gets to lobes.
Oil Filler Cap Seized
- Been thanked: 4064 times
Big pipe wrench, or, worst case, get a new one from a supporting MVS vendor in hand, then bash it off with a Swedish Thor Hammer.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
You can try to angle a straw from a can of penetrating oil up around the edge of the cap. Then take a big pie wench and go for broke. Buy another cap as well. Odds are it will start leaking after this.
Knows enough to be dangerous
- RickHaleParker
- Been thanked: 977 times
Have a chubby girl take it off? .... works for me.
Active
Past
Past
- Has thanked: 316 times
- Been thanked: 531 times
A pipe wrench or channel lock pliers tend to work well. I've dealt with some that are pretty tight. Fortunately a new cap is cheap, so it would be a good idea to get a new one if yours is all gummed up and crusty.
- WhatAmIDoing
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
Snatch a couple of almost any Volvo your year or later and replace with OEM or IPD 0 ring. Don't drop any plastic bits in the upper motor if the cap shatters. Push down a little if you can when you rotate old one off. Penetrating oil sounds good. But if you have peeked @ the cam lobes you must have the cap off already??
kashee77
- Year and Model: 99 V70 XC Turbo
- Has thanked: 2 times
Pie wench it is! Thanks for all the great replies, most appreciated. Is it just me or all those short torx head screws on the cam cover so you can see if your cams are getting oil ? Or maybe to lube them on start up because it can take so long for the head to get oil when you rebuild?
99 V70 XC
98 V70 XC (Parts Car)
previous
99 V70 XC (Parts Car)
96 850 Turbo
95 850
95 850
88 740 had 466,000
I am a bit of a fan
previous
96 850 Turbo
95 850
95 850
88 740 had 466,000
I am a bit of a fan
- RickHaleParker
You never identified year, model and configuration of the car, be mighty helpful if you did.kashee77 wrote: 03 May 2019, 21:33 Is it just me or all those short torx head screws on the cam cover so you can see if your cams are getting oil ?
VVV-Do they look like this? -VVV.
Active
Past
Past
If those are the torx screws I'm thinking of, those are to check valve adjustment on solid lifter cars.
- 1242 Views
Last post by instarx
- 3735 Views
Last post by precopster
- 746 Views
Last post by tryingbe
- 3879 Views
Last post by E Showell
- 6262 Views
Last post by erikv11
