Did you know? 🤔
Thoughts on the Kenwood DPX593BT double DIN head unit (or alternatives)?
wrybread
Year and Model: 2000 S70
Has thanked: 8 times
Been thanked: 3 times
United States of America
wrybread
Post by wrybread » Thu May 02, 2019 8:07 pm
I'm considering buying this head unit for my 2000 S70 SE:
https://www.crutchfield.com/p_113DPX593 ... l?tp=72406
New it's $140 from Crutchfield, but they also have refurbs for $110, which is probably less money than I'll spend trying to get my stock head unit to accept a line-in and bluetooth, and definitely less time. It's almost suspiciously cheap though, so I'm worried it's low quality.
The reviews are pretty good, although I couldn't find any comment on how good the FM tuner sensitivity is, which is important to me.
Can anyone see any issues with installing this head unit?
Or are there any good alternatives that I should consider?
And any thoughts on whether this is likely to have better sound than my stock SC-816?
And if I wanted to use an external amplifier with it, any tips on one that works well with all the speakers (I think 8) in my car?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 43 times
Been thanked: 154 times
bmdubya1198
Re: Thoughts on the Kenwood DPX593BT double DIN head unit (or alternatives)?
Post by bmdubya1198 » Thu May 02, 2019 9:27 pm
I don't have a ton of experience with aftermarket audio setups in these cars, but from what I understand, it's hard to get a real improvement with aftermarket head units. I have an SC-901 with the 4x50 watt factory amp under the passenger seat in both of my V70s, and I think the sound quality is fantastic. These Volvo stereos sound awesome with an amplifier, the only problem is that they aren't easy to find. I got lucky finding the full setup for my GLT, and my R of course has the full Dolby system from the factory. Honestly I prefer the sound in my GLT without the Dolby center channel dash speaker and the sound processor.
Anyway, my cousin has a JVC head unit in his S70, and the sound is good, but not nearly as good as SC-901. He's also got upgraded speakers (not sure what brand, it's been a while since we installed them) and a cheap amp (I wanna say it's a Pyle) along with a Kicker sub in the trunk as well.
I've also read about how getting the dash tweeters and rear deck speakers to work with an aftermarket amp is a challenge, but I don't know the details. Also about how upgrading the speakers isn't as easy as it normally is due to the ohm rating of the speakers, but again, I'm not an audio guy so I won't get too much into that.
2000 V70R Venetian Red/Charcoal M56 Swapped 195k
2003 S60 2.4T Silver/Black 112k
2007 XC90 V8 AWD Sport Titanium Grey/Black 166k
1991 944 Turbo Dark Green/Beige 173k
1992 245 Base White/Beige 249k
2006 BMW 330i
1999 BMW 528i
2000 S70 GLT Mystic Silver/Taupe 253k
1993 944 Base Beige/Beige 221k
1998 V70 GLT Black/Beige 199k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
wrybread
wrybread
Post by wrybread » Sat May 04, 2019 12:28 pm
Yours sounds like a much better stereo than mine. I'm not sure why exactly but having an external amp in my experience helps quite a lot. You'd think they could put the same quality amps inside head units, but apparently not. Also your head unit has twice the rated power of mine, not that it matters if you're using an external amp. I'll have to keep an eye out for those external amps under the passenger seat next time I'm at the junkyard...
The big issue for me though is getting bluetooth and a regular line in. And the ability to connect to an external amp.
With that said, does anyone have any tips on adding an external amp? If I put it under the passenger seat, any tips on how to route the speaker wires? And I know the car has 8 speakers, is it wired as if it's 4 speakers (but 2 speakers in series)?
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 25 times
crlande
Post by crlande » Sat May 04, 2019 12:56 pm
I ran my rca cables under the carpet to the amp. Crutchfield supplies connectors that enable you to plug into existing harness thus no need to run speaker wires. Rear door and back speakers were on same line.
wrybread
wrybread
Post by wrybread » Sat May 04, 2019 12:58 pm
How would you get the speaker wires from the amp under the seat to the speaker wire harness under the dash?
crlande
Has thanked: 1 time
crlande
Post by crlande » Sat May 04, 2019 3:39 pm
Carpeting easily pulls up to access the heater core and other goodies. Then I snaked it thru the carpet cut out for the rear hvac vents. Have a look under the seat you see plenty of opportunities for spots.
wrybread
wrybread
Post by wrybread » Sat May 04, 2019 3:46 pm
Awesome, thanks for that.
And is your amp just a regular 4 speaker amp? And any problems getting all 8 speakers to work?
crlande
Has thanked: 1 time
crlande
Post by crlande » Sat May 04, 2019 3:58 pm
Been so long since I installed. I know I used crossovers in front. Put tweeter in dash spot and bass/ mid in front door spot. Since the rear door and back were on same line I guess it was a four speaker amp.
bmdubya1198
bmdubya1198
Post by bmdubya1198 » Sat May 04, 2019 6:51 pm
My GLT originally had the SC-816 without the amp, and the SC-901 (which requires the factory external amp, by the way) is a HUGE improvement.
It really does surprise me that they can't get that power out of an internal amp. You'd think they would be able to get it into a smaller package to fit within the head unit.
2006 BMW 330i
1999 BMW 528i
RickHaleParker
Has thanked: 3 times
Been thanked: 539 times
RickHaleParker
Post by RickHaleParker » Sat May 04, 2019 7:43 pm
They can and do but the heat dissipation sucks and the unit does not last as long or perform as well. Heat is the number one nemesis of electronics longevity. The head unit can be better controlled with that massive heat source removed, cleaner audio processing. That one of the reasons the SC-901 sounds so good.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
