IPD sale Volvo Parts
Did you know? 🤔
LED code reader/ECC help
Peevarino
Year and Model: 2009 XC70, 97 855R
Has thanked: 9 times
Been thanked: 0
United States of America
Peevarino
Post by Peevarino » Sat May 04, 2019 7:30 am
Built a little code reader for sorting out my no heat issue, but the LED just stays on, no blinks when switched on.
It’s a 12v, and there’s a resistor, when my switch is turned off it’s off when plugged into the correct spots on the OBD output.
Ideas? Needs a different resistor?
I don’t need the heater yet, but it’s humid in Louisiana, and it would be nice to have defrost in the morning
09 XC70 3.2
97 855R
jreed
Has thanked: 20 times
Been thanked: 12 times
jreed
Re: LED code reader/ECC help
Post by jreed » Sun May 05, 2019 6:00 am
Sorry to hear you're having trouble getting the codes to read. What is the resistance value of resistor you're using? Which pins are you plugging the code reader into?
I got good results with the circuit shown below, plugging the switch between pins 5 (GND) and 6 (ECC) and the positive side of the LED into pin 16 (+12V). I used a 5K Ohm resistor in line with the LED to prevent overcurrent thru the LED.
https://www.matthewsvolvosite.com/forum ... 3&start=13
These users thanked the author jreed for the post:
Peevarino
RickHaleParker
Has thanked: 3 times
Been thanked: 296 times
RickHaleParker
Post by RickHaleParker » Sun May 05, 2019 6:24 am
The led flash code readers are for Fenix 5.2, Bosch LH 3.2 Jetronic & Motronic 4.3.
They don't work on Motronic 4.4 or Motronic 7.0.
Your 2009 has Motronic 7.0.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Peevarino
Been thanked: 0
Peevarino
Post by Peevarino » Sun May 05, 2019 8:06 am
Unsure, it’s got heat shrink over it, but I’m pretty sure that’s the issue. It’s a 12v rated led, assumed (poorly) it would work fine.
Those are exactly the pins I was using.
I posted in here because it’s for a 97 850, not the 09 I have listed in my profile.
09 XC70 3.2
97 855R
RickHaleParker
RickHaleParker
Post by RickHaleParker » Sun May 05, 2019 4:41 pm
Motronic 4.4 started showing up in some '96 850s.
"97 is pretty much the year they moved to Motronic 4.4.
Peevarino
Been thanked: 0
Peevarino
Post by Peevarino » Sun May 05, 2019 5:51 pm
Really? I had read multiple places that the R was still 4.3 in 97. It made no sense considering other 97s were 4.4
09 XC70 3.2
97 855R
RickHaleParker
RickHaleParker
Post by RickHaleParker » Sun May 05, 2019 6:14 pm
Pull the cover off the ECM box and get the number off the ECM, the number you are looking for is in the format "0 261 20X XXX" .
Peevarino
Been thanked: 0
Peevarino
Post by Peevarino » Sun May 05, 2019 8:12 pm
I will tomorrow, only number I remember from it is 628
09 XC70 3.2
97 855R
jreed
jreed
Post by jreed » Mon May 06, 2019 5:09 am
For what it's worth, the LED code reader works OK on the ECC in this car.
I'm not sure if I've got Motronic 4.3 or 4.4. I think it might be a 4.3.
I've got a '97 855 GLT wagon and the ECU is a 0261203936.
Peevarino
Been thanked: 0
Peevarino
Post by Peevarino » Mon May 06, 2019 6:03 am
It’s 9 261 203 628
ETA it’s probably a 0 not a 9
09 XC70 3.2
97 855R
